I was bored trying to get thoughts on how other people use their 7D.Im currently shooting max 18mp raw.Usually get good results.Came across Ken Rockwells 7D tips/tricks ect.Heres an something i havent thought of at this point until now.
Image Size
No one really needs 18MP. All it does is slow everything and clog your hard drive, unless you're printing 10 feet wide.
Try shooting your 7D at its M (8MP) or S (4.5MP) settings. If you look at your images at 100%, you'll see that the lower resolution shots are sharper pixel-by-pixel!
When I'm photographing family and friends, I shoot at SMALL JPG. Even SMALL is good enough for great 20x30" prints.
The smaller-sized images out of the 7D are spectacular. They are sharper and cleaner than images from cameras on which that is their native resolution. The 7D always starts with 18MP, so it looks pretty good when you set the 7D to record at only 8MP or 4.5MP.
Why? Because they use less, or no, Bayer interpolation
. No digital camera really resolves its rated resolution; they cheat and interpolate up, so at 100% at its rated resolution, no digital camera image is as sharp as a true scan from film.
At the 4.5MP setting, you have 100% R, G and B pixels, exactly as if you were using a Sigma Foveon sensor. If Sigma was selling this, they'd sell the 4.5MP (S) setting as if it were 13.5MP (also a lie).
What this means is that the lower resolution settings actually pack away lot more detail than you think. The S (4.5MP) setting of the 7D is a lot sharper than any 4.5MP camera.
M looks almost as good as L for the same reason.
If you're testing lenses, sure, shoot at L, but for everything else, try the settings for yourself, You'll probably get what you need at the smaller settings. For instance, the 11MP setting of the 7D has way more detail than any of the 12MP (native) Nikon cameras.
The resolution advantage of the 7D is obvious, even at lower settings. Try them.
Can anyone relate to what hes saying?Is this true?I guess i always thought more was better.I never print out those large of prints(8x10) at the biggest.I guess my main question is - Are they sharper at lower res?Thanks for any and all thoughts.
Im shooting an Eagle Scout cermoney sunday in a white church with a great big open glass window directly behind the subjects(grrrr).Heres my quick setup--- Manual -F5.6-8.0 - shutter 1/200-auto iso-no flash(big church)AFservo - 19pt AF.Usually does decent at this church.I have to clean up some noise but not too bad.I know its alot to digest but they all seem related at this point for what im trying to do.Thanks
Heres a link to the full article.
http://www.kenrockwell.com/canon/7d/users-guide/![]()
If you shoot at smaller megapickels, sure it looks fine full frame size - but then what if you need to crop? You have just slashed your cropping room by half. At least with 18mp, you have room to breathe
