http://jpphotography.co.nz …-quality-facebook-photos/![]()
My first tutorial let me know what you think
wildcatnzl Member 54 posts Joined Sep 2012 More info | Dec 13, 2012 00:37 | #1 http://jpphotography.co.nz …-quality-facebook-photos/
tonylong ...winded More info | Dec 13, 2012 09:55 | #2 Thanks for taking the time to do this! Tony
Dec 13, 2012 10:18 | #3 Main reason i like using 900 px, is because its an amount that i know most peoples screen resolution will be under.
tonylong ...winded More info | Dec 13, 2012 11:48 | #4 wildcatnzl wrote in post #15361838 Main reason i like using 900 px, is because its an amount that i know most peoples screen resolution will be under. Understood, although you might want to clarify that in your tutorial, since first Facebook will "fit" the image view to your screen, in fact for the "default" view it shows it smaller even if your original resolution is larger! But there is also the option to view images of a larger resolution, my suggestion is that you "expand" the tutorial a bit! [quick]I like the crop tool because it's quick, if you leave one side blank and select the entire image it is just esensialy resizing, keeping the ratio the same etc.[/quick] Gotcha, I'm just used to using the cropping tool to crop, and the "Image Size" tool to resize! [quick]Cheers for the feedback ![]() Hey, thanks for taking the time to "spread some knowledge"! Tony
doidinho Goldmember 3,352 posts Likes: 23 Joined Aug 2007 Location: Kenmore, Washington More info | Dec 13, 2012 13:01 | #5 It's my understanding that the max file size,when the hi-res box is not checked, is 960px (used to be 720), and that the max size with hi- res checked is 2048 px. Robert McCadden
Dec 13, 2012 13:19 | #6 |
tonylong ...winded More info | Dec 13, 2012 16:32 | #7 I haven't encountered "serious issues" with Facebook IQ. My tyical uploads have been about 1080 pixels in height, so approcimately matching a 1080 screen. For landscape-oriented shots, my earlier ones were all 1024 pixels wide (sized for POTN) but in recent months I've been sizing them to about 1600 pixels, making better use of the Full Screen View mode. Tony
| Latest registered member is johntmyers418 1173 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
