Thread started 13 Dec 2012 (Thursday) 08:10
Slider Questions
TheEngineer
Joined Oct 2012
Dec 13, 2012 08:10 |  #1
2 Questions - Any trick to mounting a tripod head on a slider base? I'm attempting to mount the head from my Monfrotto Monopod onto a Glidetrack Hybrid. But every time I screw the head tight onto the Glidetrack, it always stops at an incorrect angle. I need it facing perpendicular to the slider. If I loosen it at all, I get a slight wobble when using the slider.
Also, I'm attempting to mount the slider on to a Ravelli AVTP Pro Tripod. Any advice for this?
Cinéma Pure Tampa
http://www.cinemapuret​ampa.com
https://vimeo.com/cine​mapure
one2nite
Dec 14, 2012 10:29 |  #2
Try some different size washers from a hardware store.
Canon 6d +70d
Canon 17-40L / Sigma 50mm 1.4 / Canon 85mm 1.8 / Canon 18-135mm / Sigma 50-150 2.8 / Canon 580 EX / Gopro / EOS M
akivisuals
Dec 14, 2012 14:34 |  #3
Does the head from your monopod have a pan function? If you're using the head from a 561BHDV then it doesn't do pan, the pan function is built into the monopod base. That head is essentially a 701HDV head without the pan feature. The washer suggestion might make the head stop at a different angle although I don't know how solid the connection would be.
Canon 5D3 | 5D2 | 15 fish | 35L | 50L | 50 macro | 85L | 100L macro | 135L | 17-40L | 24-70L | 24-105L | 70-200L IS II | 100-400L | 1.4x | 3x 580EX | 550EX | 2x 540EZ
714 views & 0 likes for this thread, 3 members have posted to it.
Slider Questions
2032 guests, 94 members online
