Thread started 15 Dec 2012 (Saturday) 01:34
5D Mark III video setup
5W0L3
Joined Mar 2012
Dec 15, 2012 01:34 |  #1
Can someone please guide me in the right direction..
The two things il be using are:
- SmallHD monitor
- Zoom audio recorder (in hotshoe)
Basically want a rig kind of a setup.. where the monitor can be mounted onto something.. because the zoom controller will be in hotshoe (this is where id normally mount the monitor)
Want the kind of setup which can be hand held, and then quickly be able to set it up on a Slider type of a setup for some slider shots.
Any ideas?
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
Brian_R
Dec 15, 2012 10:38 |  #2
look at DSLR should rigs.
what is your budget?
akivisuals
Dec 15, 2012 13:11 |  #3
What kind of rig are you looking for? What are you shooting? I have a Gini shoulder mount rig, a Redrock Micro run and gun rig but typically mount my SmallHD DP6 with a shotgun mic on my hotshoe with a Uni-cube (external link). The monitor hangs off of the back with a small shoemount ballhead that is attached with the 1/4-20 screw to the top of the monitor. Are you using an H1, H2 or an H4n? The one thing I would caution about using the hotshoe is that too much weight will weaken it.
Canon 5D3 | 5D2 | 15 fish | 35L | 50L | 50 macro | 85L | 100L macro | 135L | 17-40L | 24-70L | 24-105L | 70-200L IS II | 100-400L | 1.4x | 3x 580EX | 550EX | 2x 540EZ
s.l.k
Joined Mar 2012
Dec 15, 2012 13:54 |  #4
If you have rails use a friction arm. Much better than having it on the cold shoe, more movement so you can place it virtually anywhere you want.
Feedback
1,150 views & 0 likes for this thread, 4 members have posted to it.
1059 guests, 104 members online
