Thread started 15 Dec 2012 (Saturday) 01:42
canon 17-55mm suddenly push-pull type
chantu
Dec 15, 2012 01:42 |  #1
In photo shoot, when adjust flash lighting, my 7d and 17-55mm did a face plant into a carpet floor. My 7d is none the worst for wear, but my 17-55 now can't zoom out anymore, only zoom in. I was able to finish the shoot by physically pulling out the lens to zoom out. Surprisingly, the lens still works fine in term of image quality, and focusing.
So, short of taking the lens in, is there anything I can do fix this lens to zoom out. Am I messing up my lens by pulling it out?
Anyone know what the cost might be?
Thanks.
SiaoP
Dec 15, 2012 02:34 |  #2
I can imagine if you keep pulling it in and out then you probably are messing up the internal mechanical linkages between the zooming ring and the lens itself. It's possible the thing is completely disconnected already and you are just sliding the zoom in and out. If there is still traces of a link left you are just making it worse. Send it in and stop playing with the zoom. Worse is if parts are loose inside and jiggling around and scratching your delicate glass elements.
My Flickr (external link) | Gear List
Echo ­ Johnson
Joined Aug 2011
Dec 15, 2012 10:11 |  #3
Did it report the correct focal length in the EXIF data after the tumble?
Canon 5D3 | 17-40 | 50/1.4 | 135/2
...and other stuff.
Flickr (external link) | EchoJ.deviantART (external link)
chantu
Dec 15, 2012 10:37 |  #4
Echo Johnson wrote in post #15369756 (external link)
Interesting. It appears that it does. So it appears the sensor for detecting the focal length is in intact. Another thing is that if the turn the zoom ring to 35mm, I can only pull out the lens to 35mm.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Dec 15, 2012 10:45 |  #5
I would think that it would be worth getting fixed right so I would send it in.
Doc Klepper in the USA
I
chantu
Dec 15, 2012 10:48 |  #6
rklepper wrote in post #15369882 (external link)
yeah, this is course the right thing to do. Where does one get a lens repaired in California, ideally the SF bay area?
1,369 views & 0 likes for this thread, 4 members have posted to it.
1396 guests, 119 members online
