For traveling I searching a way to charge my batteries for the 5D3. Is there a USB cable for the charger that I can connect to the Duracell portable USB charger ?
I'm searching now for a few hours with no real results
Superdaantje Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Dec 15, 2012 03:33 | #1 For traveling I searching a way to charge my batteries for the 5D3. Is there a USB cable for the charger that I can connect to the Duracell portable USB charger ? Wagner.photography -
lannes Goldmember 4,370 posts Likes: 8 Joined Dec 2009 Location: Perth, Australia More info | Dec 15, 2012 07:01 | #2 the pearstone might fit the bill, but you won't be able to use the duracell usb charger 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
Superdaantje THREAD STARTER Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Thank you for you help. Wagner.photography -
KhanhD "I need a grip . . . on my life" 1,523 posts Likes: 5 Joined Jun 2009 Location: Boston, MA More info | Dec 15, 2012 12:17 | #4 Why not just get another LP-E6? Seems kinda ass backwards to use a battery pack to charge a battery pack when you can just get another battery pack and charge it at home. Khanh Duong | KHDPhoto.com
LVMoose Moose gets blamed for everything. More info | Dec 15, 2012 12:19 | #5 KhanhD wrote in post #15370147 Why not just get another LP-E6? Seems kinda ass backwards to use a battery pack to charge a battery pack when you can just get another battery pack and charge it at home. +1 Moose
starkyrulz Senior Member 561 posts Joined Oct 2011 Location: Calcutta, India More info | Dec 15, 2012 13:27 | #6 +1 to the wasabi (2 with a battery charger for 29USD only - great deal on Amazon) | 5D Mark III | T3i | 24-70 f2.8 MK II L | 70-200 f2.8 IS mk II L | 18-200 f3.5-5.6 | Σ 30mm f1.4 | 50 f1.8 | 430exII | YongnouYN560 | YongnouRF603 | Vangaurd 263AT |
Superdaantje THREAD STARTER Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Dec 15, 2012 16:43 | #7 Already have enough Canon batteries. No need for new ones. Only searching for an extra option to charge when I on the go. This why I was thinking of an cable with a USB connection for the Canon charger or a charger that has a USB option. Wagner.photography -
Dec 15, 2012 17:03 | #8 I could be wrong here but I believe a USB socket provides a voltage of 5 volts nominal at around 100 milliamps. Therefore you will need a charger that will step UP the voltage to around 8 volts and interface with the battery. Even if such a thing is made it will take forever to charge your Camera battery at around 60 milliamps. I believe the LPE6 is around 1700mah capacity so 1700/60 = 28.3 hours assuming 100% efficiency and no internal resistance in the battery (both of which are imposible in 2012). Life is for living, cameras are to capture it (one day I will learn how!).
Superdaantje THREAD STARTER Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Dec 15, 2012 18:25 | #9 Sorry the link you posted is for us for in the car. For in the car I all ready have a Canon charger. Wagner.photography -
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 15, 2012 22:28 | #10 Well, like he said, your Duracell power supply has a 5V, tops, rating; you need something that pumps out at least 7.2V to recharge your LP-E6. Either carry enough batteries to get you through until you next reach a sufficiently-large power supply to recharge them (be it car, boat, plane or AC outlet) or find something that can pump out at least 7.2V and you can carry with you. Jon
lannes Goldmember 4,370 posts Likes: 8 Joined Dec 2009 Location: Perth, Australia More info | Dec 16, 2012 02:15 | #11 have never seen a Lp-E6 charger with a usb power source 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
FactionOne Member 62 posts Joined Sep 2009 Location: Lancashire More info | Aug 22, 2013 10:58 | #12 Holy threadbump, Batman!
FactionOne Member 62 posts Joined Sep 2009 Location: Lancashire More info | Aug 27, 2013 07:42 | #13 Second and last bump, I promise!
| Latest registered member is semonsters 1468 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
