Thread started 16 Dec 2012 (Sunday) 18:36
A better bounce card studio pro
Shooting
Dec 16, 2012 18:36 |  #1
I have made my supply of better bounce cards from foam paper. But the better bounce card studio pro is not so easy. Due to it's size, foam paper just flops around at that size. Does anyone know what I could make one of out at that size? I thought about white cardboard but cannot find a place that sells them one sheet at a time.
thanks.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Dec 16, 2012 18:50 |  #2
Double up on the foam by gluing two sheets back to back, add a bit of stiff wired between layers for support but with the ability to bend if needed
Shooting
Dec 16, 2012 19:16 |  #3
gonzogolf wrote in post #15374798 (external link)
I have tried 2 sheets of foam before but where it attaches to the flash, it is soo top heavy it just flops around..even with 2 sheets. Stiff wired?
dmward
Gallery: 29 photos
Dec 16, 2012 21:27 |  #4
Use the Alum wire they sell in craft stores for supporting flower arrangements.
gonzogolf
Gallery: 561 photos
Dec 17, 2012 09:48 |  #5
Shooting wrote in post #15374885 (external link)
Sorry stiff wire. Just something light to provide stability and support.
Shooting
Dec 17, 2012 15:20 |  #6
gonzogolf wrote in post #15376832 (external link)
Ok great....I'll check on it. Plus I thought maybe getting white poster board..not the thick cardboard stuff but the thin kind that you put in envelopes with enlargements.
gonzogolf
Gallery: 561 photos
Dec 17, 2012 15:23 |  #7
Shooting wrote in post #15378116 (external link)
The problem with that comes down to storage. They dont hold up well in a bag being creased and folded. Plus anything stiff enough to work is likely to be heavier than craft foam.
Alexam
Joined Jun 2011
Dec 17, 2012 15:35 as a reply to  @ dmward's post |  #8
I have made something similar to the bouncecard but using white and black foam sheets from the craft shot. Glue them together and cut the top corners off and round the base so that it will fit around your flash unit. Use velcro strip to overlap, so that it can grip the top of the flash and put two cuts about a quarter the way up, so that when fitted to the flash, you can then alter the reflected surface as much as you like with two velcro pads to hold it in place. It looks similar to the large bouncecard but costs a darn sight less and lays flat for transportation. The Bouncecard is very overpriced in my opinion.
Malcolm
Serious about Photography - Alexam Images and APA - Associated Photographic Alliance
Visit my profiles on TFP Models & Malcolm Alexander - Star Now
Shooting
Dec 17, 2012 18:05 |  #9
gonzogolf wrote in post #15378131 (external link)
True. I don't mind it be heavier than craft foam, craft foam is too flimsy anyway even with combined with another one. But I don't want it as thick as a cardboard box either, cannot bend that way.
Shooting
Dec 17, 2012 18:09 |  #10
Alexam wrote in post #15378178 (external link)
Malcolm
yeah, I have made plenty of them with the foam sheets I got from a local hobby shop but they are too flimsy to be used at the size of the studio pro that I would like to use with my manual flash strobes when I don't want to break out the umbrellas. I put 2 of them together and where the thing attaches to the flash it just flops back and forth. I need somethng like poster board but not as thick as cardboard.
digirebelva
Gallery: 376 photos
Dec 17, 2012 20:01 as a reply to  @ Shooting's post |  #11
Use the plastic canvas that u can get at the same stores as a stiffner between the foam sheets.
Alexam
Joined Jun 2011
Dec 18, 2012 04:44 as a reply to  @ Shooting's post |  #12
The foam sheets I obtained from the hobby shop were A4 size and with two sheets together there is no way they could be considered 'floppy'. In fact they are nice and firm. Perhaps you are thinking about the very airiated foam, not the 'Hobbycrafy FAB FOAM' about 2mm thick per sheet. They work well.
Shooting
Dec 18, 2012 14:34 |  #13
Alexam wrote in post #15380472 (external link)
They work at 12x14 or 11x13 size? All I have made just flops over right at the top of the flash where it attaches like it is too top heavy. I bought a 36" roll of 2mm white foam and other sizes of the betterbouncecards are fine but when it comes to the size of 11x13 at least where where it attaches by velcro strap to the flash, right above that at the flash head (where the narrow piece goes big) it flops over ..sooo flimsy..too top heavy. Going to have to put plastic between the sheets or something..so that means cutting out 3 separate things (sigh)...wish I knew what he made his from but I'm not paying $59.85 to find out.
Shooting
Dec 18, 2012 14:34 |  #14
Here is the link to the Studio Pro I'm referring to:
http://www.abetterboun​cecard.com …bouncecard-studiopro.html (external link)
digirebelva
Gallery: 376 photos
Dec 18, 2012 14:38 as a reply to  @ Shooting's post |  #15
Try this
http://www.joann.com …x18-clear/zprd_01971233a/ (external link)
Cut it a smaller than the foam and put it between the 2 foam sheets..
7,318 views & 0 likes for this thread, 12 members have posted to it.
1693 guests, 139 members online
