Thread started 16 Dec 2012 (Sunday) 18:52
How to see EXIF data from my flash
WAF
Dec 16, 2012 18:52 |  #1
I had a problem with my flash at a wedding last night. It was total blowing out my scene. The flash was supposed to be in ETTL mode but when I pulled it out this morning to see if I could duplicate the problem it was in M mode (manual). If this was the case last night then problem solved.
Looking at EXIF in Lightroom provides little EXIF for the flash. It only tells me if it fired. Is there a way to see my EXIF including details of the flash modes and settings?
Adrian ~ Canon 30D, Canon Mark3, Canon 5D MarkII, Canon 5D MarkIII, Canon 7D, Canon:70-200mm/f2.8, 85mm/1.2, 50mm/1.4, Canon 14mm Fisheye, Canon 16-35mm f2.8L, Canon 24-70mm f/2.8, USM, 1.4X, 2.0X , Quantum T5d-R flashes.http://www.adrianfreem​an.com (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Dec 16, 2012 18:55 |  #2
I'm pretty certain your flash went into TTL (not ETTL mode) because of a bad connection. ITs a pretty common thing, especially common if you use an OCF cord without a good shoe design.
WAF
Dec 16, 2012 19:30 |  #3
gonzogolf wrote in post #15374812 (external link)
I was using a 5D MarkIII with a 580EXII in its hot shoe. I would like to know if there is a way to see flash EXIF data, if there is such a thing.
jcolman
Gallery: 17 photos
Dec 16, 2012 20:03 |  #4
Afaik, there is no way to find out the power settings of a flash in the exif data.
www.jimcolmanphotograp​hy.com (external link)
gonzogolf
Gallery: 561 photos
Dec 17, 2012 09:51 |  #5
WAF wrote in post #15374935 (external link)
Regardless its probably still a connection failure. What you describe has happened to many of us here.
dmward
Gallery: 29 photos
Dec 17, 2012 11:17 |  #6
I just looked at the EXIF data in a file from a wedding last Saturday.
The file was shot raw with a 5DIII and a 600EX-RT on camera, as well as two off.
Use an EXIF tool that looks at an excruciating amount of the EXIF data, the only mention of Flash is that it was mounted and fired.
As to your problem, either it was a poor connection as mentioned, or you inadvertently tapped the button that changed it from ETTL to M.
I know its Monday morning QBing, but didn't you look at the back of your camera during the event?
I caught a mistake where I'd hit the button and changed the 600 from ETTL to M. Two bad frames, then 3 good ones of the bride and maid of honor. (I have to remember the lock position on the switch. :-) )
1,023 views & 0 likes for this thread, 4 members have posted to it.
1502 guests, 130 members online
