Not bad. They look a tad over sharpened though.
Chico, you have a lot of good things going on here. For starters, the exposures and action are great. Horizons leveled, check. Candids included (c'mon, its you, of course!). The only crit I really have surrounds the post work. To me, I think I'd like to see you tone down contrast just a touch on the action shots and give some thought to your sharpening process. To me, it looks like something got askew in some (#3 is a great example....especially the EC defender). Can you describe the technique you used and if USM, how it was applied, and what the USM settings were?
First of all, thank you (all) for your C & C, it is always appreciated and always opens pathways to contemplate.
Scott, I pp in CS6. (I have LR 4, and have just started "dabbling" in it, but still stay w/CS6 for now.) I use some "Actions" that I've created. For each "Action", if doesn't look reasonable to me, I go back "step by step" and pp. I do the following; (1) Auto Levels (Auto Tone/Auto Contrast/Auto Color), (2) Hue/ Saturation/Lightness (H = +1, S = +3, L = +2), (3) Sometimes will add Shadow/Highlights (Advanced) SHADOWS = Amt 33, Tonal Width 55, Radius 55, HIGHLIGHTS - Amt 9, Tonal Width 19, Radius 19, ADJUSTMENTS = Color Correction -9, Midtone Contrast +17, Black Clip 0.01%, White Clip 0.01%, (4) Unsharp Mask - Amt 75%, Radius 2.0 px, Threshold 3 levels, (5) if it's needed I might apply Noise Reduction using Noiseware (plugin, it used to be called NoisewarePro). Now, with each "Action" I insert a "layer" and always bring back the "opacity" to what I thinks looks reasonable. Also the above "Actions" were created with the intention that the photos would be printed on metallic paper, and their hi-res (300 ppi). When I processed the photos in this post, I did some of the "Actions" but probably should have "backed-off" more on the USM and the Contrast/Sat. BTW, using the "Actions" that I have created, it takes me about 7-10 secs to pp one photo.
