Thread started 05 Jan 2006 (Thursday) 05:58
need help with a big lens
aladyforty
Gallery: 398 photos
Best ofs: 5
Jan 05, 2006 05:58 |  #1
I have a cheap third party 100-400 F4.5-6.7 lens. Unfortunatly cant afford a canon in that range:) I have a canon 100-300 usm lens that I have got exellent shots from and got this for that little bit of extra reach. I mainly will shoot wildlife with it as its not fast enough for anything like sport. What I need to know is what kind of settings on a clear day work best for this kind of lens? I have not got much in the way of a good shot out of it at 400m yet. Im not expecting wonderful sharp shots of course with it wide open, however I cant seem to get a reasonable shot at this focal length at all:( Its not too bad at 100 to 250 though. any advise on any way to improve the use of this lens would be appreciated
FUJI XT5 + XT3 & a bunch of Fuji lenses, Mavic Air2 drone
https://www.flickr.com​/photos/25426422@N00/ (external link)
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jan 05, 2006 06:58 |  #2
If you are trying to hand hold the lens simply get either a monopod or a tripod or both. These will pay you back many times in image quality on a long lens.
Doc Klepper in the USA
I
Jman13
Jan 05, 2006 07:04 |  #3
What are the shutter speeds you're using at the longer focal lengths? Long lenses require high shutter speeds unless you're using a tripod. At 400mm on a 300D, you're looking at 1/500s or higher to have a good shot at getting sharp photos. I would also imagine that a cheap lens (especially one that's that slow at the long end) needs to be stopped down to f/8 or f/10 to get good sharpness, which puts further difficulties on shutter speed. If it's still very soft at f/11 tripod mounted, I'd say there's nothing you can do to improve the shots...it's just a weak lens.
The really long focal lengths are expensive to get quality glass. There are several decent budget options that go to 300mm, but 400-500mm you're looking at around $950 (Sigma 50-500) to really get something decent.
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
uktrailmonster
Jan 05, 2006 07:07 |  #4
If you're getting good results with the Canon 100-300 then you're probably getting what you paid for with the cheapo 100-400. Cheap zooms are often poor at their long end. Even mid-priced Canon zooms are not that good fully extended (like my 75-300 IS). If you're going to keep the 100-300 it might be worth saving for a reasonable 400 Prime.
Canon 7D, Canon D30, Canon G2, EF 24-85 F3.5-4.5, EF 75-300 F4-5.6 IS, EF 300 F4 L IS, EF 85 F1.8, iMac 24" + Canon i9100
aladyforty
Gallery: 398 photos
Best ofs: 5
Jan 05, 2006 07:25 as a reply to  @ Jman13's post |  #5
This is going to sound stupid, but I was under the impression that if the lens range is 4.5 to 6.7 that I could not shoot at F11 or anything over 6.7????
Jman13
Jan 05, 2006 08:05 |  #6
No....that's the maximum aperture of your lens. So, at 100mm, you have a maxium aperture of f/4.5, and at 400mm you have a maximum aperture of f/6.7. Your minimum aperture is probably at least f/22 (remember, larger numbers, smaller hole). I've never seen a standard 35mm SLR lens that doesn't go to at least f/22. I know there are some specialty lenses that might only close down to f/16, and a few mirror lenses with fixed apertures of f/8 or so (unchangable), but other than that you will be able to close down the aperture to a smaller number.
This explains a lot...you're shooting with a cheap lens, at it's focal extreme, wide open. Stop that thing down, use a tripod, and you'll probably see a large improvement.
aladyforty
Gallery: 398 photos
Best ofs: 5
Jan 05, 2006 09:14 as a reply to  @ Jman13's post |  #7
Thanks, Im such a dill,:o I was thinking it was like a mirror lens. I never even thought of it. Mind you Ive only had it one day:lol: Had the camera set on TV and was going by shutter speed only, then tried AV at F 6.7, will try it out tommorow.
Jon
Joined Jun 2004
Jan 05, 2006 09:30 |  #8
It is however important to remember to use a fast enough shutter speed if you're not using a tripod. If you're using the "Creative" zone (letters) settings, you can use a higher ISO number to let you get better shutter speed and aperture. If you're in one of the "Basic" (pictures & green box) zones, the camera won't let you set this (among lots of other things). At the long end, you should have a shutter speed of around 1/600 or faster. THis virtually guarantees you'll need ISO 800 on a sunny day if you want to hand-hold at a good aperture (f/11) when at maximum zoom.
Jon
Cocker Spaniels
1,100 views & 0 likes for this thread, 5 members have posted to it.
2571 guests, 94 members online
