Thread started 05 Jan 2006 (Thursday) 09:36
EOS 1D disaster!
hat-rack
Jan 05, 2006 09:36 |  #1
ok, our photographer comes back and says the camera is broken. Its an EOS-1D (the older one, not the mk2.)
so here are the pics that it takes:
http://dev.clearchanne​l.co.uk/deleteme.jpg (external link)
http://dev.clearchanne​l.co.uk/deleteme2.jpg (external link)
It seems the blue cmos thingo has gone, only yeliding red and green... What do people think? is it repairable?
Thanks!
Alex.
Curtis ­ N
Master Flasher
Jan 05, 2006 09:42 |  #2
Huh?
It's a ketchup bottle with a fluorescent orange price tag.
Both images have blue in them.
The white balance may be a bit off, but otherwise they look fine.
Is your monitor calibrated?
hat-rack
Jan 05, 2006 09:48 as a reply to  @ Curtis N's post |  #3
do you see the desk? It's goes black and white-ish half way through the colours.... especially in the first image.
I know the WB is out but it surely it cant be that (its just a quick few snaps i took to test the cam), the effect wouldnt bo so noticable. you'd get smooth colour even with the whitebalance set way out. Im using apple cinema displays to look at the image...
PaulB
Joined Apr 2003
Jan 05, 2006 10:07 |  #4
There is glare from a window (?) on the right of the first image but if you look at the colour in th notebook (red cover) on the right it is still there.
What else is wrong on your monitor?
The second image looks fine all the way across.
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Jan 05, 2006 10:10 as a reply to  @ PaulB's post |  #5
yea they looked messed up.
The desk looks like it just threw in some color here and there where it wanted to.
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
Curtis ­ N
Master Flasher
Jan 05, 2006 10:12 |  #6
Yeah I noticed the colors on the desk looked a little weird, but other parts of the image seem to be ok. When viewed at 100%, the orangish-brown shows up in blotches.
It doesn't seem right.
SWPhotoImaging
Joined Nov 2003
Jan 05, 2006 10:57 |  #7
In technical terms, I'd say it's hosed.
Canon should be able to give an estimate for repair, but it's likely time for a replacement anyway.
SWPhoto-Imaging
defordphoto
MKIII Aficionado
Joined Oct 2002
Jan 05, 2006 11:04 as a reply to  @ SWPhotoImaging's post |  #8
Either relable it your official special effects camera or send it to Canon.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
PacAce
Joined Feb 2003
Jan 05, 2006 12:20 |  #9
Were these shot in raw or did they come out like that straight out of the camera in JPEG format?
...Leo
EOSAddict
Book Committee Immortal
Jan 05, 2006 12:23 |  #10
Some better test shots might help ;)
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
gmen
Joined Aug 2004
Jan 05, 2006 12:26 as a reply to  @ EOSAddict's post |  #11
Yep... try shooting a colour chart or something... under a known light source like, er, daylight.
Good luck.
---- Gavin
TGSPhoto Editorial Sports Photography (external link) | TGS Blog (external link) | TGS Twitter (external link) | TGS Sportsshooter (external link) | TGS Tweets (external link) | TGS Facebook (external link) | LinkedIn (external link)
Longwatcher
obsolete as of this post
Joined Sep 2002
Jan 05, 2006 13:01 as a reply to  @ gmen's post |  #12
I think you have some settings set wrong in the camera or post processing.
The Sensor itself looks fine and you would not have just the blue (or green) channels go out on a CMOS or CCD sensor go out. Both types of sensors use a bayer filter array. The only way a particular set of filters could go out is if the sensor was hit with a specific frequency of laser with just the right intensity to affect only those pixels filtered for that channel a highly unlikely set of events. Also the colors that do look right require some green and blue to be correct.
I would take some more pictures of other items then the desk and then if still seeing problems then I would next recommend looking in the manual and reseting all settings to their default values. If it then is still producing problems then call Canon. It is possible the processor is buggy.
Actually are you sure you did not delete the green channel somehow in PS.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
adas
Joined Aug 2004
Jan 05, 2006 13:08 |  #13
Possible not a sensor problem, as there are samples from all three base clours.
I appears like the picture gets suddenly desaturated as the lightness, I=( 0.3R + 0.6G + 0.1B ) reach a certain value.
I wonder if the price label were blue or green, how would have showed.
Are these raw or jpg?
Anyway, befor sending it back To repair, try resetting the camera and reinstalling the firmware. The issue may be at the interpolation level.
6D, 20D, G7X
KennyG
Joined Aug 2003
Jan 05, 2006 17:05 |  #14
It looks like the nasty effects you can sometimes get when using earlier versions of CS2's ACR to convert 1DS files (which that shot is by the way).
Take a more sensible test shot and convert with DPP or another RAW converter, not ACR.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
Jon, ­ The ­ Elder
teaching fish to ride a bicycle
Joined Oct 2004
Jan 05, 2006 17:32 as a reply to  @ KennyG's post |  #15
I'm with KennyG on this one.
A 40D, a 30D, some nice glass and a great Shooting Partner.
"...As in music, so in life."
3,319 views & 0 likes for this thread, 13 members have posted to it.
EOS 1D disaster!
1769 guests, 131 members online
