Thread started 22 Dec 2012 (Saturday) 11:31
Is there any focus assist product available for 5D3 in lowlight situations?
5W0L3
Joined Mar 2012
Dec 22, 2012 11:31 |  #1
EDIT: sorry just realised.. wrong section.. can mods please move this to the camera section instead of lenses
Ive come across this problem many times now.. always on the dance floor / extremely dark environments.
My 5D3 + 600ex-rt hunts for focus forever.. and most of the time it doesn't find it.. I do manage to shoot the event eventually.. but with a lot of missed shots from the dance floor due to focus not being fast enough to capture what I want to half the time.
Just wondering if there are any products available out there which can solve this problem?.. perhaps an LED focus assist type of a product which I can connect to my camera somehow and velcro it onto my 600ex-rt which sends out a strong beam towards the subject allowing me to focus even in pitch dark?
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
starkyrulz
Joined Oct 2011
Dec 22, 2012 11:52 |  #2
i dont really have a problem getting fast AF in really low light/no light situations with a 430 exII - never used the 600 exrt on my 5dmk3. a lot of people have had success with Yongnou flashes and the remote transceiver 622. You may use any one of them.
| 5D Mark III | T3i | 24-70 f2.8 MK II L | 70-200 f2.8 IS mk II L | 18-200 f3.5-5.6 | Σ 30mm f1.4 | 50 f1.8 | 430exII | YongnouYN560 | YongnouRF603 | Vangaurd 263AT |
http://www.flickr.com/​photos/suprateep/ (external link)
http://500px.com/stark​yrulz (external link)
Heath
Joined Sep 2009
Dec 22, 2012 12:03 |  #3
Do you have the focus assist turned on for the 600ex-rt?
Edit: Maybe it does not actually work welll for some reason.
http://www.canonrumors​.com/forum/index.php?t​opic=10275.0 (external link)
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
lostinwv
Dec 22, 2012 12:08 as a reply to  @ Heath's post |  #4
I believe the 5D3 manual advises that you use single point AF (NOT "spot single"), and to stick with the middle focus point for best results with flash. Not sure if you're doing that or not, but thought I'd mention what the manual says...
Dave
Higgs ­ Boson
Dec 22, 2012 12:12 |  #5
Now that I think of it, my 5diii and 500exii has not been assisting focus even when turned on.
A9 | 25 | 55 | 85 | 90 | 135
bobbyz
Dec 22, 2012 12:51 |  #6
Dumb question, have you tried without the on camera flash? I can focus fine with 5dmk3 in very low light, like ISO25600, f2, 1/30. This with 135L. 35L was harder. Not using any flash.
I am thinking there is some camera/lens issue as this has been brought up by multiple folks.
Fuji XT-1, 18-55mm
5W0L3
Joined Mar 2012
Dec 22, 2012 13:13 |  #7
25600 ISO is not useable for events.. I try to stay under 6400 ISO at max when doing events and 5d3 with 600ex-rt struggles to lock focus in darkness at 6400 ISO.
Also I need 1/125+ shutter speed to freeze action for dance floor shots, otherwise the pics end up being blurry and unusable. I usually shoot f/2.8 (70-200) for dance floor shots.
Manav
bobbyz
Dec 22, 2012 13:32 |  #8
5W0L3 wrote in post #15397007 (external link)
I was just saying those settings to show my low light was really low. Compare 1/125 f2.8 to f2, 1/30 is 3 stops. ISO from 6400 to 25600 is 2 stops so I was shooting in 5 stops lower light (if I got my math right) than your case. No flash on my camera.
Fuji XT-1, 18-55mm
bobbyz
Dec 23, 2012 22:56 |  #9
OK, did some testing with older 550ex and I see no issues. Dark room no light, only little street light coming from the window and camera had no problem locking focus. Lens was 35L. Tried with flash off and camera took just a little more time.
Maybe something with newer 600ex flash.
Fuji XT-1, 18-55mm
5W0L3
Joined Mar 2012
Dec 23, 2012 23:04 |  #10
bobbyz wrote in post #15401877 (external link)
Hmm my main issue is with 70-200 II lens... when I tried focusing with 35L it did focus quite easily.. but that could be because its a wide lens and focusing 35mm at f/2.8 is a totally different ball game to focusing 100mm+ at f/2.8 because of how much thinner the DOF is, but I could be wrong.
Manav
emdzey01
Dec 24, 2012 02:07 |  #11
5W0L3 wrote in post #15401900 (external link)
It has more to do with the distance of the subject that you're trying to focus on. How far are your subjects that you're trying to focus on using the 70-200; compared to the 35L?
Keep in mind that the focus assist light puts out the same amount of light and is also subject to the inverse square law, which means the focus assist light reaching the subject you're trying to focus on gets exponentially weaker to the point that the 5d3 may not be able to pick up anymore due to its distance.
Maybe switch to a 6d with its -3EV center focusing point :p
my name is mjay.
Click for my transactions as a seller on POTN
5W0L3
Joined Mar 2012
Dec 24, 2012 02:44 |  #12
emdzey01 wrote in post #15402196 (external link)
haha yeah possibly.. that is probably one of the main reasons why I struggle to focus in low light.. I try to shoot from a fair way back.
Maybe I should stick to more 70mm shots and try to come in a bit closer instead of shooting further back at 100mm+.
Either that.. or find a new way of focus assisting.. maybe some sort of a bright light hmm.
Manav
dave_bass5
Gallery: 34 photos
Dec 24, 2012 10:34 |  #13
What about usin a cheap wireless trigger like the Yongnuo YN-622 Wireless TTL Flash Trigger to assist the focus?
I got have these triggers as I missed the wireless trigger from my 60D and these also fire out quite a strong AF target to help the AF system, even without a flash attached. It works really well and I also use one for night shooting.
Dave.
Gallery@http://www.flickr.com/​photos/davebass5/ (external link)
Canon R7 | Canon EOS-M50 | Canon 24-70 f/2.8L MKII | 70-300L | 135L f/2.0 | EF-S 10-18 | 40 f/2.8 STM | 35mm f/2 IS | Canon S110 | Fuji F31FD | Canon 580EXII, 270EXII | Yongnuo YN-622C Triggers.
pwm2
"Sorry for being a noob"
Dec 24, 2012 10:42 |  #14
Maybe use a IR light intended for surveillance cameras? They can be mighty strong, intended to light up objects 20-50 meters away. Yes, they need a separate power source so a reasonably large battery pack, but you should be able to auto-focus like a boss :D
bobbyz
Dec 24, 2012 13:43 |  #15
I will try with 135L and flash but that thing didn't needed no assist when I tried last time. I nailed focus easily in no light IMHO. Don't have my 70-200mm f2.8 IS II to try any more.
Fuji XT-1, 18-55mm
3,774 views & 0 likes for this thread, 11 members have posted to it.
1059 guests, 104 members online
