got a new T3i what parameter settings seem to work best to get the best jpegs with out doing much PP after the shot ?? Thanks Ron
RonnieH Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Dec 27, 2012 07:33 | #1 got a new T3i what parameter settings seem to work best to get the best jpegs with out doing much PP after the shot ?? Thanks Ron
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Dec 27, 2012 07:40 | #2 There is no one setting that will do what you want and perhaps you should have considered an upper end P&S. I see you live in Michigan; what you do today for outdoor work will likely be significantly different in July. However, the default setting should deliver something acceptable in most instances. If you feel the defaults don;t work, tell us why and we can better advise what to change. The best thing you can do is add some of your pictures here with the EXIF attached and then we can see exactly what you have done and offer better suggestions.
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Dec 27, 2012 07:45 | #3 This is not my 1st dslr and i have a G9 and G12 WAS JUST ASKING if any one had favorite settings for that cam..I NO longer posts pics on Public forms,,long story.
joeblack2022 Goldmember 3,005 posts Likes: 5 Joined Sep 2011 Location: The Great White North More info | Dec 27, 2012 07:54 | #4 The majority of people are going to say shoot RAW and post process for the best results. Joel
TSchrief Goldmember 2,099 posts Joined Aug 2012 Location: Bourbon, Indiana More info | Dec 27, 2012 11:59 | #5 Permanent banMy default is to use Standard or Landscape picture styles, depending on the shot. I crank up saturation and sharpness by one tick in each style, and leave it there. If I need ANYTHING else, I shoot raw. If you are going to shoot raw, LR4 should be your best friend.
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Dec 27, 2012 15:28 | #6 no strickly Jpeg
gonzogolf dumb remark memorialized More info | Dec 27, 2012 15:34 | #7 Ronnie H wrote in post #15413342 no strickly Jpeg Please please please reconsider. I assume you have reasons, but you are cutting off a very simple way of making a dramatic improvement to your images. By using one of the presets and doing in-camera conversions you are limiting the results. Its like picking one set of shoes to wear for a month and not knowing if you have to go to a dance or shovel out the pig barn.
| Latest registered member is semonsters 1099 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
