FORUMS Photo Sharing & Visual Enjoyment Weddings & Other Family Events
Thread started 28 Dec 2012 (Friday) 14:44
2nd Shooter Technical Issues
picworx
Joined Jun 2005
Dec 28, 2012 14:44 |  #1
I have a shot here that I am not happy with. The ceilings were dark wood not very good for speed light bounce, focus not good, how would I improve this shot. This is a place where lots of weddings take place so I would welcome your suggestions?
5DMKII was in manual and speed lite in ETTL. I used a Harbour Digital Design Ultimate Light Box modifier on the flash on a 45
The Print is What Really Matters
JakAHearts
Dec 28, 2012 15:27 |  #2
Wow, that is a cool little location! First, the low angle is unflattering, in my opinion. It might be better if you have included the boys legs and less headroom. Combined with the wide angle lens distortion, it just seems like an uncomfortable shot. The on camera flash lighting doesnt really help either. Its hard to offer advice about on camera flash without knowing what the other parts of the room look like. Are you backed against a wall here?
Here is an article I thought of when I saw your shot. - http://neilvn.com/tang​ents/with-a-little-help/ (external link)
If you take the time to learn all the topics on his site, youll be a much better photographer. :D
Shane
picworx
Joined Jun 2005
Dec 28, 2012 15:38 as a reply to  @ JakAHearts's post |  #3
I agree I cut off his legs and got too much of the ceiling and stairs. Behind me there was a hallway out to the reception area.
The on camera flash was angled at a 45 hence the blast of light.
I am seeing in articles that folks use ISO 800 inside churches and reception halls as light is so low, and maybe I should have stayed away fro f2.8 and gone with f8 or 11 for more sharpness?
mikeassk
Dec 28, 2012 20:18 |  #4
I stop down when I can. F4-F8 with a speedlite if i can.
Lower ISO is best but 200 is not necessary with moderately new cameras and also the availability of strobes you get clean images up to 1600 and in this type of dark ambient clients wont expect studio clean shots.
Your technique seems solid otherwise. If you cant balance your ambient consistently with TTL/EC then put your flash in Manual. Your TTL metered the background and blew out your subjects, or you did by over exposing them.
You say this is a popular spot, and to be honest it looks like a dungeon... so go get your exposure nailed down hours before this shot needs to be taken.
Was this shot RAW?
Stuff
ventureon
Joined Apr 2012
Dec 28, 2012 20:46 |  #5
picture will be fine. its more your composition to worry about.
Dumb down the exposure a bit in post processing, add some color effects, bam!
www.facebook.com/ventu​reonphoto (external link)
kenwood33
Dec 28, 2012 21:18 |  #6
you can bounce from the side and behind
get them all sitting down on the stairs and shoot tighter
Gearlist
jcolman
Gallery: 17 photos
Dec 28, 2012 21:59 |  #7
That is a horrible location for photos. Direct on camera flash is not very flattering in this setting. You used too much flash. Your cropping is weak.
Now, how do you improve on that? Pick locations that work with your subjects, not against them. If you must pose people on a staircase, pose them in a more interesting array. Next take your flash off camera . Better yet, add another flash so you can start to use some backlight which will help to separate your subjects from the background. You will need triggers and light stands, but that stuff is part of a pros kit. Work on balancing your ambient exposure with a little flash (properly gelled) . Don't be afraid to use higher ISO. I can show you a portrait that I shot at ISO 6400 that looks awesome.
And never shoot up at people.
www.jimcolmanphotograp​hy.com (external link)
_aravena
Dec 29, 2012 15:46 |  #8
Better bounce card would work as well. I don't specifically mean a Better Bounce Card but some diffuser that isn't a box and actually directs the light where you want it like a whale tail diffuser. No need to shoot at such an opened aperture unless you're shooting something in low light of going for a nice DOF look. Group shots should always be at least F4 (close) or higher for spaced groups so everyone is in focus.
Everyone else has covered the other areas but that's my 2 cents.
Last Shot Photography
phoenixheat
Joined Mar 2012
Dec 29, 2012 16:04 |  #9
Personally, I think what needed to happen was to kill flash power and use a slower shutter speed for more ambient light. As for fixing it, I'm not really sure. The whole room is lit by one pretty direct flash and there's not much you can do to get rid of that effect imo.
i think a cool cover up could be to turn it into a vintage looking image in post production and then get the crop/horizon right. The room looks pretty old so I think this could really work for you.
www.justinmuirphotogra​phy.com (external link)
_aravena
Dec 29, 2012 16:09 |  #10
But you can't tell what kind of ambient light there is if any so saying that isn't all helpful.
phoenixheat
Joined Mar 2012
Dec 29, 2012 16:25 |  #11
_aravena wrote in post #15421089 (external link)
there's atleast three can lights... they're in the shot.
Just ramp ISO and bring that shutter speed down quite a bit. The best part about flash is that it freezes the subject and you can really bring that shutter down quite a bit without getting camera shake/blur.
auroraskye
Dec 30, 2012 20:43 |  #12
A much higher ISO to let in more available light and a different light diffuser (one with a bounce card, as mentioned) would help. You could even drop the shutter a little more as well. But I'd have a much higher ISO.
I am super cool n' stuff.
http://www.brandithomp​sonphotography.com (external link)
Like Me On Facebook (external link)
sgtbueno
Joined May 2012
Dec 31, 2012 07:52 |  #13
To me composition should be your first worries, and then get it off the flash, you're using a f2.8, that should be enough by bumping your iso,
Wedding Photography by Felix Bueno Photography (external link) -- Facebook (external link)
1x Canon 5DIII - 2X Canon 5D Mark II - Sigma 35 1.4 - Sigma 50 1.4 - Sigma 85 1.4 - Canon 85 1.2 - Canon 100L IS - Canon 135L F2 - Canon 16-35L II - Canon 70-200 2.8 II IS - 6X YN600EX-RT -Canon 580EX II X 2- Canon 430EX II X3- Yongnuo YN-565EX - and tons of Radio Poppers :)
picworx
Joined Jun 2005
Dec 31, 2012 08:54 as a reply to  @ sgtbueno's post |  #14
I agree the flash is in your face, the light modifier I have shown earlier does send light everywhere, some people I know swear by the Lightsphere by Gary Wong but again it sends light out everywhere as well.
Would a rogue flash bender been a better choice along with higher iso like 800 with speed around 1/60th around 5.6 and of course better composition for sure.
http://www.bhphotovide​o.com …r_Large_Positio​nable.html (external link)
I will need to go back here several times for more weddings as its where most bridal parties go but not only that most venues are in poor or low light.
jcolman
Gallery: 17 photos
Dec 31, 2012 10:06 |  #15
picworx wrote in post #15426973 (external link)
A rogue flash bender is not necessarily the solution to creating a good photo. Your flash is still going to be on-camera, meaning that the light will be very flat. If you really want to produce some images that look better than snapshots, take your light off-camera.
You don't have to spend a ton of money do go with off camera lighting. You can get by with a cheap speedlight, trigger, umbrella and light stand for under $300.
Here's a stairway shot that I lit with two cheap speed lights. A small softbox was mounted to the key light. Bare light was used for the back light. I fired both with pocketwizards but you can get cheaper triggers.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i182.photobucke​t.com …g%20selects/ken​ya-668.jpg (external link)
Now, compare my image to yours and ask yourself, which one would you rather have if you were a paying client? Btw, this venue was extremely dark.
4,767 views & 0 likes for this thread
Latest registered member is ZouthernLion
785 guests, 237 members online
