Thread started 29 Dec 2012 (Saturday) 11:57
Converting Canon files to PROres for Premiere
AAphotog
Joined Apr 2012
Dec 29, 2012 11:57 |  #1
Ok, I have 2 basic setups. 1 iMac(basic but upgraded to 12gb ram) and 1 macbook pro 15.4"(basic not retina)
My question is, I am running CS6 and would like to do some video work in Premiere.
Would it be a good idea to convert all of my footage to prores?
I know that Premiere Pro accepts the footage natively, but my system lags a bit when doing grading and playback in Premiere. Would things go much smoother if I were to convert my footage first to Prores?
Also, would I be loosing a bit of quality of my footage when converting? Is it worth it?
5d3, 50mm 1.4, 70-200mm F4 L, 17-40mm F4 L
But hey, they say it's not the gear right:rolleyes:
AAphotog
Joined Apr 2012
Jan 03, 2013 23:05 |  #2
No one converts before editing?
FlyingPhotog
Cream of the "Prop"
Jan 07, 2013 03:53 |  #3
FWIW, I'm dabbling with the 30-day trial of Premiere Pro right now and footage from my 1DMkIVs dumped in and worked as is.
Same with the basic timeline in Photoshop CS6
Didn't transcode anything before editing.
Jay
BioSci
Gallery: 85 photos
Joined Nov 2010
Jan 07, 2013 21:16 as a reply to  @ FlyingPhotog's post |  #4
I'm using a MacBookPro 15.4 (retina) and CS6. I just take the video tracks off my card into Premiere without any conversion. The tracks play back smoothly even with lots of filters and effects, and the resulting video looks great even on a large-screen plasma TV.
EOS R | EOS 7D
RF 800 f/11 | 24-70 f/2.8L II | 70-200 f/2.8L II | 100-400 f/4.5-5.6L | 17-55 f/2.8 | 11-16 f/2.8
Heath
Joined Sep 2009
Jan 07, 2013 21:43 |  #5
I could not tell you exactly how to do it, but it is possible to create low res versions of your video files, use those to edit, then replace with the high res versions before you export.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
ChadAndreo
Jan 08, 2013 04:54 |  #6
why would you convert the footage when canon dslr footage works natively with premiere pro?
Photographer + Cinematographer
LETS CONNECT - SOCIAL PHOTOGRAPHY SITE LINKS | Website (external link) | Wedding Site (external link) |
| Flickr  (external link) | Gear | 500px  (external link) | Tumblr (external link)
Kentaro
Jan 08, 2013 13:09 |  #7
ChadAndreo wrote in post #15460278 (external link)
This. After some struggling with 6D footage with FCP I switched over the Premier Pro and everything works much more smoothly. I'd assume all footage from Canon HDSLRs would apply.
[6D X (17-40 // 50 // 35 // 70-200)]
AAphotog
Joined Apr 2012
Jan 08, 2013 14:28 |  #8
FlyingPhotog wrote in post #15455414 (external link)
Yes, my footage works as is as well. The problem is, how smooth it looks.
BioSci wrote in post #15459079 (external link)
I am NOT using the retina macbook pro. I am using I believe a 2009 macbook pro, and I believe an early 2011 iMac 21.5" (upgraded to 12gb ram). My playback without adding any effects even jerks every few seconds with the native 5d3 footage
Heath wrote in post #15459191 (external link)
I'll have to do some research on how to accomplish that
Read the replies above. My footage jerks without an edits. With the edits, my footage playback is REALLY slow and jerky(using the cameras native footage)
Since everyone seems to have such smooth playback, maybe my settings are wrong???
what resolution is everyone playing back their clips with? quarter, half, full
joeblack2022
Joined Sep 2011
Jan 08, 2013 16:51 |  #9
This is called "offline" editing and has its place where the file sizes are gigantic (think uncompressed HD) and back when it was more practical to digitize a tape at low-res and then do the "online" (or final) edit by batch capturing at high quality.
As to the question about why would you transcode, H.264 is a delivery format and not ideal for editing. If you are doing this commercially, there is value in transcoding to an editing format as it will hold up under processing better. It does add another step to the workflow though.
There are tools like this that are made for this purpose:
http://rarevision.com/​5dtorgb/ (external link)
However, in the OP's case it sounds like some sort of performance issue with the application or laptop that is causing the jerky playback.
OP - can you play back the files in Quicktime without any issue? Check the Adobe documentation to see if you require a specific version of Quicktime to match your Premiere version.
Getting an editing system setup is like voodoo, you need a specific computer with a specific graphics card with a specific driver to match the application version. Update one piece and you may very well have to do it all over again.
Joel
ChadAndreo
Jan 08, 2013 20:36 |  #10
AAphotog wrote in post #15462147 (external link)
If your cpu is up to par, most likely its your settings. just use the DSLR sequence preset with the correct frame rate.
BTW, If you are using the trial version, your version might be missing some of the key codecs for dslr footage.
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jan 08, 2013 20:44 |  #11
A Macbook that old is going to be Core 2 Duo based, something that was never envisaged for HD video editing.
2011 was a change over year for the iMac, is it a dual core, or quad core model?
If it is a dual core model it will also suffer under HD video.
You will also find that the AMD video card in the iMac is doing nothing in Premier Pro, as it is only able to make use of a select number of Nvidia cards.
Finnaly, the Macbook and 21.5in iMac only have 5400rpm hard drives in them, which maybe to slow.
Have you tried Final Cut Pro X?
It is less of a resource hog than Premier pro and is able to leverage the graphics card in your iMac.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
dfinn
Joined Jan 2012
Jan 09, 2013 18:14 |  #12
I used to convert when I used FCPX, no need to anymore with PP.
AAphotog
Joined Apr 2012
Jan 09, 2013 18:17 |  #13
Moppie wrote in post #15463766 (external link)
The iMac is a 3.06GHz Intel Core i3
You are also correct in mentioning it has a 5400rpm drive
The macbook also has the same drive with a 2.66 GHz Intel Core 2 duo processor.
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jan 09, 2013 22:43 |  #14
AAphotog wrote in post #15467990 (external link)
Theres your problem :cool:
Forget about the macbook, it will never be fast.
Changing the drive in the iMac to a 7200rpm drive, or using a thunderbolt external drive will help.
But, you still can't leverage the GPU on it with Premier Pro, and may find that the only way to edit smoothly is with Final Cut Pro X, or try Premier Elements.
Ideally you need an i5 or i7 based computer with some fast hard drives.
D. ­ Vance
Jan 09, 2013 23:23 |  #15
I'm assuming it is only in your preview, not when saved; mine does that all the time with Premiere Elements 10, and I've wrestled it through 2 2 hour DVDs, switching between 7 cameras (in the last one, 5 in the first). It is just the computer not being fast enough to handle the processing load to generate the preview on the spot. Saving should be fine.
Just check that your project settings are on DSLR, with the right FPS. (29.97 for me; shows 30).
I wonder if the video editors on The Titanic ever went, "Sorry, I can't right now. I'm busy synching the Titanic..."
2,751 views & 0 likes for this thread, 10 members have posted to it.
611 guests, 125 members online
