My USB 2.0 external hdd transfers usually around 17 mb/sec. When plugged into a 3.0 port it runs at 34mb/sec.
So, I guess USB devices are sometimes limited by the computer port?
Canon_Lover Goldmember 2,673 posts Likes: 101 Joined Jan 2011 Location: WA More info | Dec 29, 2012 13:02 | #1 My USB 2.0 external hdd transfers usually around 17 mb/sec. When plugged into a 3.0 port it runs at 34mb/sec.
RHChan84 Goldmember 2,320 posts Likes: 24 Joined Apr 2011 Location: Mass More info | Dec 29, 2012 13:22 | #2 Are you sure? There are burst speeds when using USB2.0 as well. Best way to to use CrystalMark test to see average speed. Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Dec 29, 2012 18:42 | #3 Yes, give CrystalMark a try and see what you get with that between the two. [Gear List | Flickr
YP5Toronto Senior Member 499 posts Joined Oct 2008 Location: Markham, Ontario More info | Dec 29, 2012 21:07 | #4 Yes....in general, most USB 2.0 devices work faster on USB 3.0 connection. I have experienced this and tested this with a variety of storage devices/media. Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
| Latest registered member is semonsters 1081 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
