This forum is awesome, first of all. I will probably be spending more time here after this! I wish I had discovered it sooner.
The reason I'm posting here I screwed by hot shoe (literally) and I figure I may get some ideas on how to fix it. I got a 430EXII for Christmas and in my ultimate wisdom, I left it attached to my T3i when they both took a tumble onto a tile floor. They both worked fine afterwards, they don't even have any visible scratches. The only damage was a bent hot shoe. If I pushed the flash onto the camera, it worked flawlessly, but it would not work if I was not pushing it.
I took the protective plate off, expecting to just take the hot shoe out, bend it, and put it back. But alas, the rear-right screw head was broken. That was the side of the hot shoe that was bent up, so it just ripped the screw head off when the flash hit the floor. Understandable because these are tiny screws, but my problem now is how do I get the rest of the screw out of the camera? Here's a cell-phone picture of what I'm dealing with:
![]() | HTTP response: 404 | Byte size: ZERO |
You can see the black dot in the middle of the right-rear hole. That's the screw. And here's one of the intact screws on a penny to give you an idea of how tiny these things are.
If I can get that screw out, I can order a new screw from Canon for something like $7 with shipping, screw it in and everything's ok. If not, a service rep I talked to quoted about $200 to have it fixed by Canon. Freaking ouch.
I already tried bending the hot shoe back and putting it in with only 3 screws. It works for a while, but eventually the weight of the flash pulls that unsecured corner up. So any ideas? I was thinking a tiny dab of super glue on another screw and then maybe I can turn it with that? But I wouldn't want the super glue to stick to the camera either.
580 EX 11 flash- manfrotto tripods and monopods.
