I know the lens difference and cost differences, but how does the imaging compare between these two? I'm thinking of finally giving up with the DSLR (IDMKIII) and going light.
Jannie Goldmember 4,936 posts Joined Jan 2008 More info | Dec 30, 2012 14:27 | #1 I know the lens difference and cost differences, but how does the imaging compare between these two? I'm thinking of finally giving up with the DSLR (IDMKIII) and going light. Ms.Jannie
Dec 30, 2012 15:38 | #2 Jannie wrote in post #15424214 I know the lens difference and cost differences, but how does the imaging compare between these two? I'm thinking of finally giving up with the DSLR (IDMKIII) and going light. I looked at that selection early this year, just couldn,t justify the cost of spending £2000 + on the Fuji against £600 on the G1x. Canon 5D mk3, 50mm 1.4, 17-40L, 70-200L, 100-400L, Canon 100L macro, Canon 2 x G1X, Speedliite 430 EX all supported by Gitzo and Benro.
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Dec 30, 2012 16:52 | #3 Only one has fast primes and lets you build a system. That can be a pro or a con depending on what you are after. Taylor
binliner Senior Member 711 posts Joined Jan 2007 Location: Suffolk, UK More info | Dec 31, 2012 02:51 | #4 There's no comparison really. The Fuji has a bigger sensor, better dynamic range, faster lenses, more flexible (there is a zoom lens in the range with more to come), better viewfinder and in terms of image quality (which is what you particular asked for) it's superb. I used one for a day and was amazed at how sharp the raw files were... better than my 7D and up there with the best APS-C cameras. The only area the G1-X wins is price but then it's not really a fair comparison. Justin
vmaniqui Member 40 posts Joined Oct 2012 More info | Dec 31, 2012 02:53 | #5 also wanted to get advise on these cameras.
nonick Goldmember 1,588 posts Joined Jun 2009 Location: NYC More info | Jan 12, 2013 00:06 | #6 I have XE-1, the little brother of the Xpro-1 that shares virtually the same specs with the Xpro1 minus the OVF, less the size and plus a high resolution EVF. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
Jan 13, 2013 06:29 | #7 nonick wrote in post #15477764 To add more excitment... Fuji just announced X100s... If you have read the release of the X100s, you should have already known fuji implements a whole new super fast (hybrid) AF system, a totally innovative MF system (the world's first digital split screen), new X trans sensor, processor, best EVF etc to the new camera. This new release gives a good ideas of the direction the next X-pro/ X-E model will evolve. BUT ...If you shoot RAW, you have to be patient. The only real weakness fuji system currently face is the lack of good raw support. But solution should be here soon. Differnet people has different needs. If I have to choosie from GX1 and Xpro 1 , I will take fuji. If I need a good P&S, I would seriously consider Fuji X20. Can,t understand Fuji,s design philosphy here the X100s a fixed lens at 23mm is predominately a landscape lens so why have something very fast focussing on a semi static scenario. Canon 5D mk3, 50mm 1.4, 17-40L, 70-200L, 100-400L, Canon 100L macro, Canon 2 x G1X, Speedliite 430 EX all supported by Gitzo and Benro.
x_tan Cream of the Crop More info | Jan 13, 2013 07:14 | #8 nonick wrote in post #15477764 ... Talking about Image quality, It is A LOT better than 7D and much better than 5DII at hi ISO, ... I wish I believe you or you're right; but my gut tell me above statement just well over the top. Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
sticknpuck Member 205 posts Joined Jan 2011 Location: GVRD More info | Jan 13, 2013 11:49 | #9 It's not over the top if you consider the high ISO noise the 7d exhibits. The Fuji far and away produces cleaner images with more dynamic range. Nothing is perfect though and the transition to mirrorless from any rebel or better dslr can be somewhat difficult. Focusing can be tricky... Matt
binliner Senior Member 711 posts Joined Jan 2007 Location: Suffolk, UK More info | Jan 13, 2013 13:36 | #11 nonick wrote in post #15477764 Talking about Image quality, It is A LOT better than 7D and much better than 5DII at hi ISO, and of course it outclasses the GX1 without any question. Just to balance things up slightly, the G1-X beats the Fuji hands down at anything over 60mm Justin
Jan 13, 2013 14:32 | #12 binliner wrote in post #15483064 Just to balance things up slightly, the G1-X beats the Fuji hands down at anything over 60mm ![]() Also the G1x beats the Fuji hands down on viewing height range, the Fuji only works from about 1 foot to 6 foot, the G1x can get shots from ground zero to about 9 feet in height. The G1x gets where other cameras can,t reach. Canon 5D mk3, 50mm 1.4, 17-40L, 70-200L, 100-400L, Canon 100L macro, Canon 2 x G1X, Speedliite 430 EX all supported by Gitzo and Benro.
ifi Member 173 posts Joined Jun 2010 Location: Texas More info | Jan 13, 2013 19:29 | #13 vmaniqui wrote in post #15426388 also wanted to get advise on these cameras. me too
Luckypenguin Senior Member 612 posts Likes: 3 Joined Apr 2011 Location: Brisbane, Australia More info | Jan 13, 2013 21:06 | #14 Image quality: a very subjective topic. There are certainly technical aspects that can be measured but it's not possible to measure someone's individual tastes in what they do and don't like from one camera to the next. For example, test results tell me that the 16MP Sony NEX cameras should easily have better image quality than the G1X and yet, I preferred the look from the Canon over that from the NEX 5N. I can see where the two cameras are different, but the bigger numbers from the Sony don't translate into a preferrable image output...for me. Nic - flickr photostream
nonick Goldmember 1,588 posts Joined Jun 2009 Location: NYC More info | Jan 13, 2013 22:00 | #15 Judder Man wrote in post #15481876 Can,t understand Fuji,s design philosphy here the X100s a fixed lens at 23mm is predominately a landscape lens so why have something very fast focussing on a semi static scenario. I would have thought they would announce fast focus designs at the longer end of 100mm + where the action is and better suited. It's a range finder style camera... 23mmx1.5 = 34.5mm, good for walk around, street and environmental portrait, bokeh. Nothing is confusing to me... Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
| Latest registered member is semonsters 1062 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
