Thread started 30 Dec 2012 (Sunday) 21:57
creative ways - holding a reflector with minimal gear (one-man photographer)
the.forumer
Joined Oct 2011
Dec 30, 2012 21:57 |  #1
i've been searching around for solutions or creative ideas on how a single photographer can free his hands off the reflector (without any assistant) and yet not need to carry a tripod/arm just to hold the reflector in place.
another way is to get the subject to hold it, or simply to put it on the floor or let it lean against a wall - but these have its disadvantages as well - the amount of light might not be sufficient or there are limited compositions because i need to avoid putting the reflector into the frame too.
suggestions? :D
jcolman
Gallery: 17 photos
Dec 30, 2012 22:21 |  #2
I've used a spring clamp to attach my reflector to a light stand. But it only works under ideal conditions, ie no wind.
www.jimcolmanphotograp​hy.com (external link)
mattograph
"God bless the new meds"
Dec 30, 2012 22:28 |  #3
Me too. Justin clamp on the top and spring clamp on the bottom.
This space for rent.
happy2010
Looking for the light first
Dec 31, 2012 01:23 |  #4
There are always these-
Lastolite UPLITE:
http://www.lastolitesc​hoolofphotography.com/​using-the-uplite (external link) (22:45 minute product video)
http://www.bhphotovide​o.com …sort&Ntt=Lastol​ite+Uplite (external link)
http://www.lastolite.c​om/uplite.php (external link)
Lastolite TRIGRIP (the medium size-30" is still manageable by solo photographer):
http://www.bhphotovide​o.com …ort&Ntt=Lastoli​te+Trigrip (external link)
Good luck on finding a solution that works for YOU and your situations.
Mary
MARY
Wilt
Jan 05, 2013 12:36 |  #5
And there are arms like the Photoflex Litedisc Holder
http://www.bhphotovide​o.com …ic_Light_Disc_H​older.html (external link)
and the Photoflex Litepanel Crossbar
http://www.adorama.com …OGPkvbt0bQCFYF7​QgodiXMAzA (external link)
MDJAK
Jan 05, 2013 19:53 |  #6
I often lean mine against my leg
the.forumer
Joined Oct 2011
Jan 05, 2013 20:00 |  #7
thanks guys for the suggestions. i'm leaning more towards travel-friendly solutions, if possible at all. :)
bobbyz
Jan 05, 2013 20:37 |  #8
Larsen reflectasol. Bigger ones stand on their own but would be nice to use with a stand with a grip arm.
Fuji XT-1, 18-55mm
StayFrosty
Joined Aug 2012
Jan 06, 2013 02:55 |  #9
It always seems to need a bit of improvising when using a reflector doesn't it. I use a cheap set of plastic clamps I bought from B&Q, link:
http://www.diy.com …t-11247685?skuId=1175839​0 (external link)
They are pretty versatile and I try to rig them up to whatever is available..
I think the California Sunbounce looks like a clever piece of kit for working solo. Crazy expensive for me though!
flickr (external link) Vimeo (external link)
photoddgraphy
Joined Jan 2013
Jan 06, 2013 11:38 |  #10
The cheapest option is surely just to use one of those bulldog clip things you can buy??
Put a strip of foam/sponge over each metal surface and jobs a goodun. They even come with pre-cut holes in the handle so you can fix and hold them to a tilting flash stand/tripod and can even be fixed in place if you have a bolt for the 1/8, 1/4 fitting that you use :)
Ideal for travel too - weight = less than 100g :D
Probably not particularly professional but certainly for a beginner, with the 20 quid reflectors on Amazon, you can have a pretty flexible setup for about £22...
Facebook (external link)
Canon 5D Mk III, 16-35L II 2.8, 24-70L II 2.8, 50 1.4, 85 1.8, 135 2.0, 70-200L II IS 2.8, 430EX II x 2, Lastolite Ezybox, PocketWizard Mini TT1, Flex TT5 x 2, AC3
aliengin
Joined Mar 2011
Jan 07, 2013 09:35 |  #11
the.forumer wrote in post #15425734 (external link)
suggestions? :D
I have a Lastolite Trigrip. It is way overpriced compared to regular reflectors but in most cases its worth it! Get a velcro strap and when you can't hold it you can strap it to anywhere from the grip
Ali Engin Photography (external link)
umphotography
grabbing their Johnson
Gallery: 21 photos
Jan 07, 2013 09:45 as a reply to  @ aliengin's post |  #12
Voice activated light stands are the only way to go,,tell em to bring a friend.
Mike
www.umphotography.com (external link)
Scott_1469
Jan 07, 2013 18:14 |  #13
I know this is a fairly obvious solution, but I often just use my remote with a tripod when flying solo. I can then freely maneuver either a light or reflector (sometimes both) while triggering the camera by remote.
Gear List | My Flickr Site (external link)
Quote from my oldest: "Dad, I liked you a lot better when you had the small camera"
bobbyz
Jan 07, 2013 20:14 |  #14
Scott_1469 wrote in post #15458327 (external link)
Would love to see some portrait shots. This will work if shooting pretty slow apertures. How you AF remotely? Best thing is what Mike suggested above. Reflectors need adjustments all the time to get the light the right way on model's face and no way you can do that with any clip etc with relflectors being on a stand.
Fuji XT-1, 18-55mm
3,898 views & 0 likes for this thread, 12 members have posted to it.
1501 guests, 134 members online
