Thread started 06 Jan 2006 (Friday) 13:53
? about correcting horizons
Brandy327
Joined Mar 2004
Jan 06, 2006 13:53 |  #1
I have several shots of my children sitting on a sea wall in front of the ocean. The ocean isn't quite straight across so I fixed it. But then I noticed that the sea wall they were sitting on isn't straight. So do I correct it so the horizon is straight or that the sea wall is straight? If you need an example, I can post a pic. :) Thanks in advance!
Canon 20D with BG-E2 grip
Canon 28-135mm USM IS
Canon 18-55mm
Canon 75-300mm
Canon 420EX Speedlite Flash
Canon 50mm f/1.4 USM
Canon i9900
jfrancho
Jan 06, 2006 14:07 |  #2
Without seeing the picture, I'd say the horizon should be straight. Horizons are always straight when you look at them (unless you're lying down) whereas other elements can change, depending on your perspective. That isn't to say you can't get an interesting composition from a crooked horizon.
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Jan 06, 2006 14:10 |  #3
Yes, the horizon should be straight. It's possible to take the picture at an angle to the wall, thus making it appear tilted. But the horizon should always be level.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
Brandy327
Joined Mar 2004
Jan 06, 2006 15:36 |  #4
Thanks for the advice! :) I appreciate it!
Canon 18-55mm
Canon 75-300mm
Canon i9900
875 views & 0 likes for this thread, 3 members have posted to it.
2235 guests, 127 members online
