Thread started 02 Jan 2013 (Wednesday) 11:40
s100 focus issues
ekinnyc
Joined Mar 2011
Jan 02, 2013 11:40 |  #1
was using my S100 to take some NYE pics at a friends house. the lighting was good enough where the camera didnt need to focus-hunt, and yet for some reason i was getting soft focus with it. i tried various modes - auto, P, Av, M.... in all cases, sometimes when i would compose a shot, the camera would get focus lock but the image was significantly blurry. if i tried to refocus the same shot, it would focus lock perfectly fine on the next shot.
i dont have any samples, but a good example would be a couple of people next to the xmas tree. plenty of contrast, and enough light, and yet it would be soft. any ideas?
6D| 35mm f/2 IS
Buying/Selling Feedback
ekinnyc
Joined Mar 2011
Jan 07, 2013 12:02 |  #2
bump?
6D| 35mm f/2 IS
hnikesch
Gallery: 24 photos
Jan 07, 2013 18:35 |  #3
You may have enabled close up focus mode, try a reset
Hans
tmwag
Brown Noser has crush on Suzyview
Jan 07, 2013 19:26 as a reply to  @ hnikesch's post |  #4
IS settings, check IS mode...continuous, shoot only, off
Heath
Joined Sep 2009
Jan 07, 2013 20:18 |  #5
Do you have an example you could post?
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
ekinnyc
Joined Mar 2011
Jan 07, 2013 22:59 |  #6
tmwag wrote in post #15458591 (external link)
i have it on Continuous, and Powered IS is on. what should it be?
Heath wrote in post #15458811 (external link)
i dont, i deleted them all unfortunately. imagine you are doing a focus test using 5 people of equal height spaced evenly apart. you get a good focus lock on the middle person (the camera beeps, you get the green box), yet the whole image is blurry
edit... looks like i do, ill post it shortly
6D| 35mm f/2 IS
ekinnyc
Joined Mar 2011
Jan 07, 2013 23:39 |  #7
for some reason i cant display the focus point in DPP, but heres the pic
Screen shot 2013-01-08 at 12.36.10 AM (external link) by ekinnyc (external link), on Flickr
1/60, f/2.0, ISO640
focus, if i recall, was on the couple
6D| 35mm f/2 IS
CactusJuice
Jan 08, 2013 06:42 |  #8
ekinnyc wrote in post #15459591 (external link)
Umm not very helpful for troubleshooting purposes. Why did you strip off the exif data?
Someone else can correct me but I don't think DPP shows focus point for PowerShots. Mine doesn't for my S100. Anyway, keep in mind this particular feature isn't the be all end all. For example, it only shows the focus point, not what you focused on. And it wouldn't show after an image had been edited in DPP.
hnikesch
Gallery: 24 photos
Jan 08, 2013 07:37 |  #9
If you had center point selected the camera may have focused on the tree not the people
Hans
Hans
jack880
Gallery: 13 photos
Joined Apr 2011
Jan 08, 2013 17:10 |  #10
My mum had the same issue with hers - she didn't realise that you have to half press the button down till the square turns green, then press it all the way down to take the photo - she was just pressing the shutter down all in one go straight away, not giving the camera time to focus....
https://www.flickr.com​/photos/jackhenriques/ (external link)
1DX, 7D, 20D, G7X II, 70-200 f/2.8 L IS II, 24-70 f/2.8 L, 16-35 f/2.8 L II, 50 f/1.8 II, 50 f/1.4, TS-E 17 f/4 L, 8-15 f/4 L, Sigma 17-50 f/2.8, Sigma 8-16 f/4.5-5.6, Sigma 150 f/2.8 macro, x1.4 extender II, Kenko extension tubes, 430 EX II x 2, DJI Mavic Air
ekinnyc
Joined Mar 2011
Jan 08, 2013 17:26 |  #11
jack880 wrote in post #15462885 (external link)
is that how it works ;)
as i mentioned, i was getting focus lock (the green square).... but no sharp focus
6D| 35mm f/2 IS
tmwag
Jan 08, 2013 19:02 |  #12
ekinnyc wrote in post #15459510 (external link)
anything but off
ekinnyc wrote in post #15462947 (external link)
The best way for anyone to help is for you to provide a better sample image...with exif intact
ekinnyc
Joined Mar 2011
Jan 08, 2013 21:29 |  #13
tmwag wrote in post #15463337 (external link)
that was some harmless sarcasm
here is the full export, exif intact. original pic was just a screenshot from LR3
IMG_0042 (external link) by ekinnyc (external link), on Flickr
Exif data
Camera Canon PowerShot S100
Exposure 0.017 sec (1/60)
Aperture f/2.0
Focal Length 5.2 mm
ISO Speed 640
Exposure Bias 0 EV
Flash On, Red-eye reduction
X-Resolution 240 dpi
Y-Resolution 240 dpi
Software Adobe Photoshop Lightroom 3.6 (Macintosh)
Date and Time (Modified) 2013:01:08 22:26:47
Sensitivity Type Standard Output Sensitivity and Recommended Exposure Index
Date and Time (Original) 2012:12:31 23:44:08
Date and Time (Digitized) 2012:12:31 23:44:08
Max Aperture Value 2.0
Subject Distance 0.37 m
Metering Mode Multi-segment
Focal Plane X-Resolution 13651.87713 dpi
Focal Plane Y-Resolution 13636.36364 dpi
Sensing Method One-chip color area
Custom Rendered Normal
Exposure Mode Auto
White Balance Auto
Digital Zoom Ratio 1
Scene Capture Type Standard
Lens Info 5.2-26mm f/?
Lens Model 5.2-26.0 mm
Compression JPEG (old-style)
6D| 35mm f/2 IS
tmwag
Jan 08, 2013 21:38 |  #14
You are kidding me? That image says you..are a tool....at least
imjason
Joined Nov 2010
Jan 08, 2013 21:50 |  #15
so, my question is, the focus issue only happened at the nye party?
and it never happened before and you cannot replicate it again?
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
6,423 views & 0 likes for this thread, 7 members have posted to it.
s100 focus issues
1154 guests, 118 members online
