Thread started 02 Jan 2013 (Wednesday) 12:38
5d2 won't turn on. Fast flashing red light.
dfinn
Joined Jan 2012
Jan 02, 2013 12:38 |  #1
Last night my 5d2 was acting kind of strange. It was rebooting itself frequently. I removed my grip and it seemed to stop doing it and go back to normal. This morning I go to turn my camera on and it doesn't turn on. I pull the battery, put it back in and the red light by the dial is flashing fast and the camera doesn't turn on. I tried other batteries, tried pulling the CF card and putting it back, no change.
Anyone else ever run into this? Anything else I should try?
TSchrief
Joined Aug 2012
Jan 02, 2013 14:24 |  #2
Try pulling the battery AND the date/time battery. Let it sit for a few (15?) minutes without either battery installed. That should force a hard-reboot. While the batteries are out, clean all the electrical contacts. This is more of a generic computer solution than a specific camera solution. Good luck.
dfinn
Joined Jan 2012
Jan 02, 2013 14:30 |  #3
I wasn't aware of the date/time battery, thanks for the suggestion. Unfortunately that didn't fix it.
John ­ from ­ PA
Joined May 2003
Jan 02, 2013 14:40 |  #4
One thing to add to TSchrief's procedure - while all batteries are out turn the power switch to the ON position and hold down the shutter release for 15 seconds. This will insure that you have bled off any residual power that mioght still power up the circuitry. Then...
Turn the power switch to the OFF position.
Reinstall all the batteries.
Turn the camera back on ON.
If you have forced a hard reboot you should have to reset the date and time.
Beyond that, get yourself a flashlight and look very carefully into the CF card slot. You may perhaps have a bent pin.
TSchrief
Joined Aug 2012
Jan 02, 2013 14:47 |  #5
dfinn wrote in post #15435745 (external link)
How did you even try it if you are posting 7 minutes after receiving the suggestion to leave the batteries out for 15 minutes?
dfinn
Joined Jan 2012
Jan 02, 2013 14:49 |  #6
No change unfortunately. All the pins look good. CF card slides in and out easily, I also tried a couple of different CF cards.
What's interesting is that as soon as I put the battery in, even with the power switch set to "Off" the light flashes.
dfinn
Joined Jan 2012
Jan 02, 2013 14:50 |  #7
TSchrief wrote in post #15435830 (external link)
Good point, I missed the part about 15 minutes. Doing that now.
dfinn
Joined Jan 2012
Jan 02, 2013 15:15 |  #8
No change after waiting for a while.
Fester
Joined Sep 2011
Jan 02, 2013 15:21 as a reply to  @ dfinn's post |  #9
Wow! I'll bet your tough on your kids!:rolleyes:
dfinn
Joined Jan 2012
Jan 02, 2013 15:34 |  #10
I deserved it. And I bet his kids listen to instructions better than I do. :)
Gameface
Joined Mar 2011
Jan 02, 2013 15:56 |  #11
dfinn. I have read about that exact phenomenon on several forums over the years. Not one single person was able to come up with a solution. Every one had to go into service to Canon to get fixed. Sorry to be the bearer of bad tidings.
dfinn
Joined Jan 2012
Jan 02, 2013 16:47 |  #12
That is a bummer but it's pretty much what I was thinking would need to happen. I'm heading to my local authorized canon repair center in about an hour to have them check it out.
TSchrief
Joined Aug 2012
Jan 02, 2013 17:20 |  #13
Sorry to hear it wasn't an easy fix. Good luck at Canon.
3,453 views & 0 likes for this thread, 5 members have posted to it.
992 guests, 111 members online
