Thread started 03 Jan 2013 (Thursday) 01:20
Lee filter kit?
photopr0
Joined Oct 2011
Jan 03, 2013 01:20 |  #1
Need some suggestions as to what I should buy to start my kit (I still need the filter holder)? I have about $400 dollars to spend. What would you guys recommend for sunsets, clouds, and water?
Canon 5D Mark II | Canon 7D Gripped | Canon Rebel xti
Canon 100-400 F4.5-5.6L | Canon 70-200IS F2.8L |Canon 100L| Canon 17-40L | Canon 28-135 | Canon 85 F1.8 | Canon 50 F1.8 II
flickr (external link) | Facebook (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jan 03, 2013 01:46 |  #2
Holder, wide angle adapter ring, 2-stop and 3-stop hard grad, 2 and 3 stop soft grad, Big Stopper and square CPL are the things I'd target. Since those will all add up to more than your $400, I'd get the 3 stops and CPL, then the 2 stops and Big Stopper as funds/time allow.
Superdaantje
Jan 03, 2013 02:10 |  #3
I would start with a ND Grad 0.9 hard & Soft and a 0.6 Hard + Big Stopper or 0.9 ND ProGlass
And you can later at the CPL filter and extra ND & GND filters
Wagner.photography -  (external link) Workshops photography in the Netherlands & Indonesia -_-
Gear list (external link)
Blurr ­ Cube
...a lucky id-iot that didn't get electrocuted...
Jan 03, 2013 12:32 as a reply to  @ Superdaantje's post |  #4
Lee Graduated ND set (.3, .6, .9) - soft, along with Big Stopper, and the Foundation kit. ;)
| Canon EOS Systems |
Snydremark
Gallery: 66 photos
Jan 03, 2013 13:50 |  #5
Honestly, if I were doing it over again, I'd skip the sets simply because the 1-stop (.3) filters are almost never enough; I use the 2 and 3-stops (.6 and .9, respectively) individually, or stacked, a lot, but nearly never the 1-stops.
Mix and match from the rest of the suggestions, though :)
alintx
Jan 03, 2013 13:52 |  #6
While we're on this . . . I don't get how the little brass knob is supposed to work on the side of the holder. Mine doesn't stay in any particular position . . .
Al
5DIII, 5DII, T2i, TS-E 24mm f3.5L II, 17-40 f/4L, 24-70mm f2.8L, 50 f/1.4, 85 f/1.8, 70-200 f/2.8 L II, 135mm f/2L, 180mm f/3.5L, Canon 40mm f/2.8, Sigma 50-500 OS, 3 x 600EX-RT, ST-E3-RT, RRS tripod + BH-55, bags out the wazoo, other crap +++
Aerial Photography (external link)
Snydremark
Gallery: 66 photos
Jan 03, 2013 14:03 |  #7
It's just a pull tab, basically. It's so you can withdraw the holding tab that keeps the adapter ring attached to the holder. Not sure if that answers your question, or not.
RHChan84
Joined Apr 2011
Jan 03, 2013 14:04 |  #8
It's not suppose to. It's holds the kit holder to the adapter and it should stick out a little bit (looking like it's not in all the way). It should be enough to hold it tight and not fall but loose enough to spin the filter holder for the filters, like a CPL.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
alintx
Jan 03, 2013 14:37 |  #9
RHChan84 wrote in post #15439946 (external link)
That is what I thought, but it is looser than is reasonable. It holds, but not well enough to keep me from being nervous.
Thanks.
Al
Bonbridge
Gallery: 20 photos
Joined Jan 2012
Jan 03, 2013 16:08 |  #10
I would go for:
- ND Hard grad: (0.3, 0.6, 0.9) (Could be used as full ND too)
- ND Soft grad: (0.6)
- 4x4 Polarizer
- Bigstopper
Next to a foundation kit and adapter.
5DII + 6D | 16-35/4.0L IS | Σ35/1.4A | 40/2.8 | Σ85/1.4A | 70-200/2.8L IS II
iMac Retina 5k | i7 | 24Gb RAM | 512GB Flash | 4GB M295X
Website (external link) | flickr (external link) | Instagram (external link)
photopr0
Joined Oct 2011
Jan 04, 2013 12:22 |  #11
Also are there any cheaper lens adapters? From ebay maybe?
RHChan84
Joined Apr 2011
Jan 04, 2013 23:07 |  #12
Are you trying to step down or step up. I have a 77mm adapter but ended up picking up step up rings for my lens that has a 72mm threads. But stepping down might cause vignetting.
Feedback
photopr0
Joined Oct 2011
Jan 05, 2013 01:05 |  #13
I don't have the kit yet I just feel $30-60 is a bit high for an adapter ring...
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Jan 05, 2013 01:18 |  #14
eBay has 3rd party adapter rings. No idea how good they are, but it's just a metal ring. I haven't seen any wide angle adapters, though.
Where are you finding a filter kit? I have been on the waitlist at 2filter forever.
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
photopr0
Joined Oct 2011
Jan 05, 2013 01:26 |  #15
The filter holder can be found at BH Photo (external link)
6,311 views & 0 likes for this thread, 13 members have posted to it.
Lee filter kit?
1352 guests, 173 members online
