Thread started 07 Jan 2006 (Saturday) 01:27
Canon E1 hand-straps... How are they?
piku
Joined Jun 2004
Jan 07, 2006 01:27 |  #1
Experience w/ them? I like to shoot events and move around a lot. So this might be good for me. Let me know otherwise...
TIA
Sherwin
PS. Too bad I bought an op-tech neck-strap (super classic strap) at Adolph Gasser store in SF today based on impulse =( ...they only do store-credit if I return it.
Sherwin Techico (external link) ~●~ My Photos (external link)
30D + SD880IS ~●~ Tamron 17-50/2.8 + 28-75/2.8 ~●~ 50/1.8 + 70-200/2.8L IS + kit
Sigma EF500 DG Super + Maha MH-C401FS ~●~ Stofen OM-C ~●~ LSPJ II ~●~ Sterlingtek BP-511s + NB-4Ls
Burton Zoom pack ~●~ Naneu Pro Lima ~●~ (sold)Crumpler 6MDH
Carzee
Jan 07, 2006 01:33 |  #2
Excellent. And if you don't have a BG-E3 or whatever battery grip you should check out http://www.camdapter.c​om (external link) and look over their lovely straps. I have the Canon E1 on my 10D with BG-ED3 and also have the Camdapter strap on my 20D without grip... and I find I prefer the camadapter and no battery grip.
Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images (external link)
Mark_Cohran
Joined Jul 2002
Jan 07, 2006 01:33 |  #3
I have two and I think they're great. They allow me to hold the camera securely when walking around. They work well with the POTN straps too, because you can just unclip the POTN strap when you want to just use the hand strap.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
Carzee
Jan 07, 2006 01:42 |  #4
Here's a shot of the 10D with the E1. Just slip your hand in there and... enjoy!
piku
Joined Jun 2004
Jan 07, 2006 01:57 |  #5
Wow, expensive =]
Which one you recommend for 20D ... Double Ended or the 2x Arca Style?
Mike ­ K
Joined Apr 2001
Jan 07, 2006 02:06 as a reply to  @ piku's post |  #6
piku wrote:
Wow, expensive =]
Thinking ahead I would consider the double ended Arca style bottom plate along with one of their hand straps. If you wanted to place the camera on a tripod you have taken up the tripod hole, so you need the Arca Swiss style camera plate on the bottom. You then get an Arca Swiss style tripod clamp from RRS, Wimberley or Kirk. Using the double ended plate you can attach the camera neck strap to the left top and bottom of the camera.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
jjonsalt
Jan 07, 2006 06:29 as a reply to  @ Mark_Cohran's post |  #7
Mark
I guess I don't understand. Do you have both a neck strap and the hand strap on the camera? Do both straps afix to the upper right eyelet?
cdifoto
Don't get pissy with me
Jan 07, 2006 06:50 as a reply to  @ jjonsalt's post |  #8
There's a small metal tab that the neck strap loops through:
Carzee
Jan 07, 2006 07:00 |  #9
Most of the time I don't use the neckstrap.
By way of explanation I have a bit of a bodgey system that works for me -so far. I really only use the neck strap when I change cf cards or change lens. I attach the neckstrap to the lower section of the handstrap. I do not use the eyelet thing sitting on top at all. I have a fast clip on, clip off D hanging on the neck strap. They are metal and therefore a possible risk to the camera paintwork etc. So I fitted some rubber heat shrink on the D to fix that. Here's a std cheap carbiner 'D'.
IMAGE: http://www.keyosk.co.uk/images-products/pr-key-accessories-key-clips-carabiner-clip-a61-1.jpg
jjonsalt
Jan 07, 2006 07:37 as a reply to  @ cdifoto's post |  #10
Then I also must have an E1.
MALI
Jan 07, 2006 10:46 |  #11
piku wrote:
Experience w/ them?
I cannot do without it. It is a MUST. Get one and you will ask yourself, how did I do without it so far?
MALI
Canon 20D, 10-22, 24-70L,70-200L f/2.8 IS, 580 EX, RS-80N3, EP-EX15, BG-E2, E1.
condyk
Africa's #1 Tour Guide
Jan 07, 2006 13:08 |  #12
Are there people who don't use a handstrap :shock: :shock:
https://photography-on-the.net …/showthread.php​?t=1203740
Tomasz ­ Dziechciarz
Joined Jan 2005
Jan 07, 2006 13:19 |  #13
This strap save my camera many times esspecialy in crowded places ... you simply feel your camera ...
Tomasz
www.dziechciarz.art.pl (external link), www.pbase.com/tomaszd (external link),
5D,3 +grip, 20D+grip,17-40L, 24-105/4L, 70-200L, EF- Primes 35/1,4;50/1,4;85/1,8;1​35/2, 580EX,580EX ll, ST-T2, KENKO TC 1,4 and KENKO ext tubes,TAMRAC Pro 5 & Turbo Cyber Pro bag & Compu Rover AW
Carzee
Jan 07, 2006 15:26 |  #14
Ditto and double for the official POTN Optech Neckstrap!
Click the POTN shop link at the top of the page for a look...
gale
Joined Nov 2005
Jan 07, 2006 16:54 |  #15
argh. I want one of these for my XT but it IS expensive-doesn't even include the strap itself, $35 just for the adaptor. I have carpal tunnel syndrome and I think this would really help me out (my hand goes numb after just a few shots, but I do always use my neck strap).
complete beginner
Rebel XT w/18-55 kit lens
17-55 F2.8 IS USM, 50mm 1.8, 28-105 3.5/4.5 II USM, 380EX flash, Lowepro Slingshot AW100
plus Canon G2, Canon S410 and Canon Sureshot Classic 120 film
(I'm a Canon gal :) )
5,243 views & 0 likes for this thread, 17 members have posted to it.
1779 guests, 130 members online
