Thread started 06 Jan 2013 (Sunday) 19:43
Camera Focus Issue on my T1i?
drocpsu
Jan 06, 2013 19:43 |  #1
Since the summer (June, specifically), I've been trying to figure out if my camera has a focusing issue, or something similar. It seems to always be a bit out of focus and colors/detail seem to be muddled, for lack of a better term. It is pretty much the same with all of my lenses. I've linked a couple full-res photos to show them. Both were taken in JPG Full Resolution (High Quality) format
#1 - Taken with sigma 10-20mm wide angle lens
ISO200, f/9, 1/100 sec, 18mm, auto WB, Camera mode: Av
http://www.flickr.com …6/sizes/o/in/ph​otostream/ (external link)
#2 - Taken with 18-55mm kit lens
ISO200, f/9, 1/320sec, 46mm, auto WB, Camera Mode: Av
http://www.flickr.com …3/sizes/o/in/ph​otostream/ (external link)
Here are a few unedited example photos from the trip before I started noticing the change in image quality:
http://www.flickr.com …5/sizes/o/in/ph​otostream/ (external link)
http://www.flickr.com …8/sizes/o/in/ph​otostream/ (external link)
Since its the same with all lenses, I assume that it has to be a problem with the body. Does anyone have any insight? It's extremely frustrating to get photos that look like this all of the time, and it's caused me to almost stop going out with my camera entirely. If it's a problem, I just want to get it fixed.
http://www.flickr.com/​photos/drocpsu (external link)
Canon T1i | 18-55 IS | 55-250 IS | 50mm f/1.8 II | Sigma 10-20mm f/4-5.6
| Slik & Giottos tripod
va_rider
Jan 06, 2013 19:45 |  #2
none of your links work. All Private.
Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
I'm not a professional photographer, and I don't want to be.
drocpsu
Jan 06, 2013 19:50 |  #3
va_rider wrote in post #15453973 (external link)
Thanks for the tip. I was trying to see if I could publish the images without them showing up publicly in my photostream. Fixed the privacy permissions.
drocpsu
Jan 07, 2013 15:09 as a reply to  @ drocpsu's post |  #4
Anyone have any advice for me about this?
kf095
Out buying Wheaties
Gallery: 63 photos
Jan 07, 2013 15:29 |  #5
I see no issues.
What do you expect from images like this taken with zooms? Take the shot from the distance and see every little crack at each brick in full size picture?
amfoto1
Jan 07, 2013 16:59 |  #6
That first shot doesn't appear to have been taken with the Sigma lens. In fact, all the shots you linked appear to have been taken with the Canon EF-S 18-55 IS. So we are really looking at possible issues with one lens here.
Some ideas...
1. Do you have "protection" filters on your lenses? If so, take them off. Clean the lenses, too (micro fiber cloth, lens cleaning fluid and a final polishing with a lens pen are recommended).
2. Viewing a 15MP image on a computer monitor at 100% is like looking at the a four foot wide print from 18" away. Use reasonable viewing sizes. Looking at the Flickr 1600x1067 pixel size files of your shots (instead of the full size), they appear a lot sharper. The photo of the church has some chromatic aberration where the roof meets the sky, but thats no surprise (and can be fixed in post processing).
3. if not already doing so, use a matched lens hood on your lenses. It can help keep oblique light from causing "veiling flare", which reduces contrast and color saturation, can make images look washed out and soft.
The f9 aperture you used should be fine, but be aware that when using smaller apertures (f11, f16, etc.), sharpness of fine details can suffer due to diffraction. You might want to Google and read up on this.
Plus, all lenses have "optimal" apertures and, with zooms, focal lengths where they perform best. Your two "problem" images were shot at f9, one at 18mm the other at 46mm. Two of the shots you are happy with are shot at f5.6 (wide open) and 55mm. The third is at f5 and 36mm (also probably wide open). It's possible your particular lens performs better wide open than stopped down.
4. Some sharpening might be possible. But that usually should be done last, after the image has been cropped to it's final, intended size.
5. The monitor you view your images on is important. A graphics quality monitor isn't cheap, but if you are serious about your photography, can be a good investment to help maintain your sanity. If going to that extent, you also should consider calibrating your monitor and your entire workflow on your computer. That means buying a calibration device and software... and using it periodically to maintain accurate color, contrast, light levels with your computer. Forget about using a laptop... the viewing angles are too variable and we use them undear a wide variety of lighting conditions.
I also notice the two images you are concerned about appear to have been shot on overcast days, in lower contrast light. All of the earlier ones were shot on sunnier days, when light was more contrasty, and that can give the impression of greater sharpness too.
6. Have your camera sensor cleaned or do it yourself. If there is a lot of adhered dust or oils on it, those can effect overall image sharpness. Also, lenses and cameras get out of calibration over time, with use and wear and tear, so a proper checkup and some adjustments might be in order. Lenses also can have an element get decentered, usually from a bump or something. That usually effects sharpness on one side of an image more than another, though. Lenses do wear out, too.... just from regular use, focusing and zooming mechanisms inside get loose and aren't as precise. Higher quality lenses are usually more durable than inexpensive kit lenses that are comprised of a lot of plastic.
7. It might help to shoot RAW and develop your images into JPEGs (or Tiffs or whatever) in post-processing on your computer. This puts you more in control of many factors, and preserves the maximum available digital data from each shot for you to work with. All digital cameras shoot RAW files to start with.... But when you set the camera to JPEGs, it is converting the RAW files via some global settings you've made in the camera menu, and in the process throws away a lot of the data from the original capture, leaving you a lot less to work with if you want to make any adjustments later.
Both the "poor sharpness" images appear to be correctly exposed, but there can be some loss of apparent sharpness if you have to make adjustment to exposure after the fact. RAW files are more easily adjusted for exposure, color balance, etc. And more or less sharpening can be applied.
If you are going to continue shooting JPEGs, you have to be sure of your camera's settings... the Picture Profile in particular determines contrast, saturation and sharpness of the JPEG image. You also have to watch noise reduction settings, since it works by slightly blurring fine details. None of these were high ISO shots, so I doubt that noise reduction was much of a factor here.
1,293 views & 0 likes for this thread, 4 members have posted to it.
540 guests, 153 members online
