OK, any tips and tricks for this? I have an HP EX495 running Window Home Server that I house my images on. I need to find out how to squeeze the most performance out of using this with Light Room.
First, I could upgrade to a different computer for a server if it will cure the issue, but I'm thinking it won't since retrieving images should mainly be using network resources and not CPU or memory. I have everything hooked to a Netgear router and it's taking several seconds for an image to load to full resolution. This is killer when editing 300-400 photos. Is there a way to make this faster other than loading the images to a local disk and editing it that way before transferring them back to the server? The problem with that is once they're off the local desk Light Room's catalogue doesn't see the images.
