Hi,
It's my understanding that the graph display on my 600EX is meant to represent what range the flash would work correctly at. That is, when my flash has a black bar between 20ft - 60ft, and it says 20ft-60ft @ 2.8 next to it, it means that being closer than 20ft would be overexposed and being farther than 60ft would be underexposed?
If that is the case, why when I change the flash compensation from 0 to -1 the range actually gets higher, say from 20-60ft to 40-60ft? Shouldn't the range get nearer?
Confused.
