I got an amazing deal on this lens so I had to jump on it. The first two outings with it was a learning curve. Even though it is lighter than the Mark I version, it still is a handful.
After the third for forth attempt, I did manage to get a pretty sharp pictures of a squirrel in the back yard. This was at 1/800 F5.0 handheld.
After talking to a few friends they said that a gimbal head was the way to go so I found a used one. This really make this a breeze to use.
Now, I think I need to go out and take some pictures but with this lens, you are self conscience about people's reactions due to it's size? You almost think you need some lanyard around you neck with a bunch of press passes.
I'm also not real thrilled with the Canon case this comes with - it is very big and would rather have a hard case just big enough to hold the lens and hood securely. Any ideas?
Thanks,
(you think the 400 is a draw..)
