Watch the following video with the title:
CamRanger on GeekBeat TV and get there by http://www.camranger.com/![]()
RonnyGeenen Member 125 posts Likes: 1 Joined Dec 2011 More info | Jan 10, 2013 14:09 | #1 Watch the following video with the title:
cisobe Senior Member 257 posts Likes: 1 Joined Jan 2007 More info | Jan 10, 2013 17:49 | #2 I thinking watched the video before... $300 is a bit steep, but the fact that it works on multiple cameras is nice... but right now it only supports iOS devices... 5D MKIII|7D w/ Grip|EF-S 10-22MM f/3.5-4.5|EF-S 17-55MM f/2.8 IS|EF 24-105MM f/4L IS|EF 50MM f/1.4|EF 70-200MM f/2.8L IS|85mm f/1.8|35mm f/2 IS|70-300MM f/4-5.6 IS|580EX|Manfrotto 055PROB|2x PCB Einstein 640
betatech Member 51 posts Joined Dec 2011 Location: Indy More info | The cost is due to license from canon. Canon provided the SDK to allow the device to br made and charged an outrageous license fee and RESTRICTED it to only that device currently. I myself have been attempting to code an interface to allow use of both Nikon and Canon on Android and iOS -- Nikon has been the only one to release a USEABLE SDK to work off of. Canon still will not provide the SDK without an outrageous fee and excessive restrictions. Canon T3i ( DryOS to Android Custom)- Canon 18-55mm IS kit lens, Minolta 50mm f1.2, Minolta 135mm.
kpritts Senior Member 329 posts Likes: 4 Joined Nov 2010 More info | Feb 16, 2013 10:07 | #4 I have it and it works as advertised. Photo transfer to device is substantially faster than Canon's WFT for my 1DsIII and 1DIV. Photos are displayed nicely. I am considering using it for a large screen display for an upcoming family photoshoot so folks can see it right away. KDPritts Photography (http://kdpritts.com
Coral Senior Member 285 posts Likes: 1 Joined Dec 2012 Location: Ohio More info | Apr 01, 2013 12:47 | #5 But this may do the same thing from the OEM: http://www.amazon.com …FP4/ref=cm_cmu_pg__header Living the Dream
Jptenberg Member 224 posts Likes: 23 Joined Sep 2010 Location: Minneapolis, MN More info | Apr 02, 2013 09:42 | #6 That does look like the same thing as the cam ranger router, but in order to use the cam ranger software, you have to register the router with cam ranger, and I would assume that they will not register a serial number that was not purchased from them. I could be wrong though... _______________
Coral Senior Member 285 posts Likes: 1 Joined Dec 2012 Location: Ohio More info | Apr 02, 2013 09:53 | #7 Jptenberg wrote in post #15782453 That does look like the same thing as the cam ranger router, but in order to use the cam ranger software, you have to register the router with cam ranger, and I would assume that they will not register a serial number that was not purchased from them. I could be wrong though... You are correct, that's there copy protection. What I would like to see if someone who purchased the Camranger could try the TP-LINK TL-MR3040 out and see if it works. Living the Dream
samsen Cream of the Crop 7,468 posts Likes: 239 Joined Apr 2006 Location: LA More info | Apr 02, 2013 10:08 | #8 Nice. Weak retaliates,
lovemyram4x4 Goldmember More info | Apr 02, 2013 11:59 | #9 Or the guys that have already made apps that work thru usb cables could update them to work thru the TP-LINK TL-MR3040
| Latest registered member is Frankie Frankenberry 1373 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
