Probably a very basic and simple task to you seasoned editors out there, but I'm just starting to have a bit of fun so...
How do I stop the sky being blown out during editing without making everything else under exposed using aperture?
Brelly Senior Member 331 posts Joined Oct 2012 Location: Nottingam, England. More info | Jan 10, 2013 14:14 | #1 Probably a very basic and simple task to you seasoned editors out there, but I'm just starting to have a bit of fun so... http://500px.com/ChrisBrelsford
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 14:22 | #2 You may not be able to do so in PP.
Jan 10, 2013 14:30 | #3 Lincolnshire Poacher wrote in post #15471403 You may not be able to do so in PP. The aim is to correctly expose both sky and land correctly in camera and make only small adjustments PP. The way to do this may involve the use of hard or graduated filters, or bracket your exposures then merge in PP. Best way is to post an example and let us check it out for you. Thanks for the reply, but I'm afraid not much of that makes much sense to me, sorry! Very very new to the world of editing! Image hosted by forum (632252) © Brelly [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. http://500px.com/ChrisBrelsford
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Jan 10, 2013 14:31 | #4 That just looks like a drab, dreary, foggy and uninteresting sky. The only way to fix it would be to wait for better light before pressing the shutter button.
Jan 10, 2013 14:35 | #5 Numenorean wrote in post #15471456 That just looks like a drab, dreary, foggy and uninteresting sky. The only way to fix it would be to wait for better light before pressing the shutter button. Fair shout. This was at about 12/1 in the afternoon so there wasn't really much hope of the light getting any better! This was at the bottom of a valley as well, so the fog was pretty thick too. What do you think of the editing over all? Anything you like/don't like? Any changes you'd make? http://500px.com/ChrisBrelsford
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 14:41 | #6 That image looks as if it was quite misty, so you would be unlikely to extract any sky detail whatever you did.
Jan 10, 2013 14:52 | #7 Lincolnshire Poacher wrote in post #15471512 That image looks as if it was quite misty, so you would be unlikely to extract any sky detail whatever you did. In then vast majority of occasions, the sky is much brighter than the subject you are photographing. Unfortunately, the camera sensor has a far less dynamic range than the human eye, so whilst you can see detail in the subject and sky, the camera can see detail only in one or the other, depending on the setting of your meter and where your viewfinder was aimed. (Yes this subject is complicated for a start, but the more you use your camera, the easier it will become). This, along with composition is the very essence of photography. I could type on here all night and still only scratch the surface of exposure and exposure compensation, so I suggest you read some tutorials freely available on the net, or buy a good book which will explain all. Can I assume you know nothing of the use of "exposure lock"? This is a technique which can help in getting a balanced exposure of light and dark portions of an image. Some information on the use of this may be in your camera manual, but again book learning will be time well spent. Oh okay, so it's not user error in editing more the actual shooting then? http://500px.com/ChrisBrelsford
Jan 10, 2013 14:54 | #8 kjonnnn wrote in post #15471533 I think you also should understand that this isnt about editing, its about understanding the dynamics of trying to get very bright and very dark all on the same exposure .... exposure latitude. That begins before you press the shutter, choosing the right location, the right time of day in the right lighting. understanding what to meter, and how to meter it, and on a really basic level how your meter really works and what it is trying to do. A blown out sky will always be a blown out sky even in the best post. No I know it's not all about editing, but this was pretty much as good as it got all day, so I've got what I can from a bad bunch, I think. Like I say, I'm still very new to photography and trying to get in as much as I can, but it doesn't always stick! http://500px.com/ChrisBrelsford
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 15:03 | #9 OK. Overall the composition is fine, but it appears a half to a full stop under exposed. Given the conditions, the colours are the best you could expect, so go back there in clearer weather and try again, using what you will have learned by then about exposure.
gjl711 Wait.. you can't unkill your own kill. 57,730 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jan 10, 2013 15:09 | #10 Very simple, don't adjust the whole frame. Not sure about aperture, but in other photo editing programs you can create an adjustment layer, then make your adjustments on that layer, then use the GND effect to blend the two layers. Not sure why, but call me JJ.
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 15:10 | #11 gjl711 wrote in post #15471625 Very simple, don't adjust the whole frame. Not sure about aperture, but in other photo editing programs you can create an adjustment layer, then make your adjustments on that layer, then use the GND effect to blend the two layers. http://www.youtube.com/watch?v=fl5bROuI4GQ This technique won't work with a completely blown sky.
Jan 10, 2013 15:14 | #12 Lincolnshire Poacher wrote in post #15471601 OK. Overall the composition is fine, but it appears a half to a full stop under exposed. Given the conditions, the colours are the best you could expect, so go back there in clearer weather and try again, using what you will have learned by then about exposure. Focus looks a tad soft. Did you use a tripod? If so you also need to read about hyperfocal distances and the correct use of aperture for effective depth of field. If you did not use a tripod, you should have done. The small twigs upper left need cloning out as they are distractions and add nothing to the shot. Sorry if this comes across as negative, but you are on a steep learning curve. Keep at it and keep posting shots for critique and you will grt there. If you have a local photography club, that may well be an excellent place to develop your skills. Or try a learning day with a good tutor.
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 15:17 | #13 Brelly wrote in post #15471654 bit short of money at the mo. Another thing to learn: The next bit of kit you need is always just outside your budget!
gjl711 Wait.. you can't unkill your own kill. 57,730 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jan 10, 2013 15:18 | #14 Lincolnshire Poacher wrote in post #15471636 This technique won't work with a completely blown sky. No, can't be totally blown out. Once blown, it's gone. All you can do is turn it gray. Not sure why, but call me JJ.
LincolnshirePoacher Member 115 posts Joined May 2011 Location: Lincolnshire, UK More info | Jan 10, 2013 15:22 | #15 Just one other piece of advice on composition. When deciding on a landscape view, if the sky is grey, dull or otherwise uninteresting, you can often compose so as to cut out or minimise the sky in the shot by, for instance taking the shot from a slightly higher level and pointing your camera lower.
| Latest registered member is johntmyers418 1239 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
