Hello,
My friend is having her birthday in a club and she asked me to be the photographer. I'm just not sure if I have the right equipment. My equipment is in my sig, so please let me know your thoughts.
Thank you!!!
DavidSR Goldmember 1,308 posts Joined May 2008 Location: Rowlett, TX More info | Jan 11, 2013 08:58 | #1 Hello, T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
PhotosGuy Cream of the Crop, R.I.P. More info | Jan 11, 2013 09:22 | #2 That should work, but I don't suggest that you go in cold. Try to get some test shots before the event. FrankC - 20D, RAW, Manual everything...
sapearl Cream of the Crop More info | Jan 11, 2013 09:34 | #3 PhotosGuy wrote in post #15474636 That should work, but I don't suggest that you go in cold. Try to get some test shots before the event. Tips for Xmas Ball Please What Frank says - good advice. GEAR LIST
Jan 11, 2013 13:34 | #4 Thank you for posting that link!! There's tons of info! T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
sapearl Cream of the Crop More info | Jan 11, 2013 13:52 | #5 You're welcome David - it probably will be too dark for metering also, so you'll likely have to shoot in manual, drag your shutter and have ETTL fill in the exposure with your flash. GEAR LIST
tonylong ...winded More info | Jan 13, 2013 01:21 | #6 You have to choose whether this will be "practice" in which case you can experiment, or whether you will be "pro", in which case you will need to do some practice! Tony
| Latest registered member is semonsters 1600 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
