Thread started 11 Jan 2013 (Friday) 13:05
Tutorial : How to make DLO work with non compatible lenses
yb98
Joined Feb 2003
Jan 11, 2013 13:05 |  #1
The tutorial is here : http://digitol.free.fr​/forum/viewtopic.php?f​=2&t=136 (external link)
I propose to create and maintain a thread that will contain for each non-compatible lens, the best compatible lens to use. So if you find a good compatible lense that can be used for a given non-compatible lens, please post the information in the table thread so as I will add it to the table.
Thanks.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
yb98
Joined Feb 2003
Jan 11, 2013 13:23 |  #2
The correspondance table between compatible lenses and non-compatible lenses is here : http://digitol.free.fr​/forum/viewtopic.php?f​=2&t=138 (external link)
Best DPP Threads
tzalman
Fatal attraction.
Jan 11, 2013 18:13 |  #3
My version of ExifToolGui (3.38) doesn't have the Direct button, but I discovered something better and easier. Select Modify in the menu bar and then Canon Maker Notes. In the submenu you have two choices; the first, Lens Type (For DPP) opens a window with a list of Canon lenses. Pick the one you want and click Save. At the bottom of the window it says it is for the 20D and 350D only, but it worked fine for my 5D2. The second choice, Lens Model, opens a text bar where you have to type in the name of the lens and is supposed to be for later camera models.
As you can see in the screen capture, I changed my Tamron 24-70 to Canon EF 24-70. DPP accepts it and applies DLO.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/2/LQ_632422.jpg
Image hosted by forum (632422) © tzalman [SHARE LINK]
Elie / אלי
yb98
Joined Feb 2003
Jan 11, 2013 23:34 |  #4
Thanks Elie. It seems indeed easier with your version of exiftoolgui. It's strange that they removed this possibility in the recent version...
DO you have a link to download this older version ?
Best DPP Threads
yb98
Joined Feb 2003
Jan 12, 2013 01:18 |  #5
ok I have found a link to this older version here : http://freeweb.siol.ne​t …foto/exif/exift​oolgui.zip (external link)
Best DPP Threads
2,175 views & 0 likes for this thread, 2 members have posted to it.
1513 guests, 166 members online
