As it says in the title really, eventually looking at trying my hand at some macro when I can afford another lens. So what lens would you guys recommend for a beginner in macro without breaking the bank?
Brelly Senior Member 331 posts Joined Oct 2012 Location: Nottingam, England. More info | Jan 11, 2013 14:16 | #1 As it says in the title really, eventually looking at trying my hand at some macro when I can afford another lens. So what lens would you guys recommend for a beginner in macro without breaking the bank? http://500px.com/ChrisBrelsford
Jan 11, 2013 14:39 | #2 I'm going to preface this with "I haven't tried yet", but from reading this forum and aside research; I'll outline my current plan (in progress). [6D]
Jan 11, 2013 14:47 | #3 w0m wrote in post #15475848 I'm going to preface this with "I haven't tried yet", but from reading this forum and aside research; I'll outline my current plan (in progress). I want to hand hold my 100mm macro outdoors on a canon ff body (no built in master). Starting with a 430ex ii on camera; I have found I need cross light to avoid shadows/loss of detail in subject. So I found this guy for cheap.. http://www.amazon.com …=dual+flash+bracket+canon I believe I should be able to mount 2 Canon 270exIIs on it with diffusers; and spread them out enough to remove any shadows. I actually picked up an ST-e2 off craigslist Thursday; and plan on using that to control them(Hoping angle is right else I'll need to put a reflector on lens or some such to bounce the signal back..). I have 1 270ex II in the mail now; and will order the second after playing with the first. (Will give me more creative portrait/controlled macro lighting regardless I think). Hope my thought process/scheming helps (either as a path to follow or path to avoid) Ah, I'd not considered this approach yet, so yes, it does give me something to think about! Thanks! http://500px.com/ChrisBrelsford
DanThoman Goldmember 2,646 posts Likes: 124 Joined Aug 2009 Location: georgia lake country More info | Jan 11, 2013 15:44 | #4 The best macro for a budget is the canon 100mm macro. If you can afford it get the 'L' although it costs 2X as much. Dan
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jan 11, 2013 16:02 | #5 Clarification needed. "If you're not having fun, your pictures will reflect that." - Joe McNally
Jan 11, 2013 18:12 | #6 Curtis N wrote in post #15476202 Clarification needed. Thread title says "Macro flash?" But you're asking about a macro lens. As far as macro flash is concerned, do a forum search for the title, "Show us your macro rig." You'll get a lot of good ideas. Sorry, badly worded! http://500px.com/ChrisBrelsford
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Jan 11, 2013 18:49 | #7 Ok. You can go back and edit your original post. "If you're not having fun, your pictures will reflect that." - Joe McNally
Jan 11, 2013 19:23 | #8 DanThoman wrote in post #15476114 The best macro for a budget is the canon 100mm macro. If you can afford it get the 'L' although it costs 2X as much. wOm - have you purchased that flash bracket and if so how well does it work? I made something similar using the 3/4 inch plastic flex arm and it works 'ok' with the 430 but not great with the 580. In the photos the flex arm looks like it uses the 1/2 inch links. I'm thinking about a couple of 270's when they come out with the radio version. I haven't ordered the bracket yet; I'm waiting to see if I'm happy with a single 270 for general off camera use before I order a second and the bracket (Snowing here; so no nature hikes for a while). From what I've read about the bracket; it holds the weight of the 270 fine; but might struggle of anything bigger. If I find I'm not happy with the wireless capabilities of the 270; or that it doesn't put off enough light/i just think it's crap; I'll have to look into buying or making a more hefty bracket and bigger flashes to use. (I <3 my 430). [6D]
LVMoose Moose gets blamed for everything. More info | A speedlite and a pringles can? Moose
JoeRavenstein Goldmember 2,338 posts Likes: 1 Joined Mar 2010 Location: E Tx More info | Jan 11, 2013 19:51 | #10 If you're going to be doing much macro work consider acquiring a ringlight flash, it will prevent shadows on what ever you plan to shoot. Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
Jan 13, 2013 06:11 | #11 LV Moose wrote in post #15476922 A speedlite and a pringles can? https://photography-on-the.net …?p=15134139&postcount=883 Hahaha, that's brilliant! Actually considering that, might have to get some prawn crackers to go with and use them as the diffuser! http://500px.com/ChrisBrelsford
Jan 17, 2013 10:42 | #12 For followup; I received my first 270exII in the mail; and on a 6D with a new-to-me ST-E2; the wireless works suprisingly well (as in; firing consistently in situations where when my 600D simply wouldn't). It still doesn't go around walls; but I don't have to be nearly as careful with placement as I did previously (st-e2 vs 600d master). I'll be purchasing the bracket above and a second 270exII in the near future. [6D]
Jan 17, 2013 12:23 | #13 w0m wrote in post #15500352 For followup; I received my first 270exII in the mail; and on a 6D with a new-to-me ST-E2; the wireless works suprisingly well (as in; firing consistently in situations where when my 600D simply wouldn't). It still doesn't go around walls; but I don't have to be nearly as careful with placement as I did previously (st-e2 vs 600d master). I'll be purchasing the bracket above and a second 270exII in the near future. Oh great, thanks. THat's handy to know, I'm hopefully going to be having a 270exii myself soon (hopefully for a bargain too!). Why did it struggle on your 600D? Am I going to get the same problems on my 650? http://500px.com/ChrisBrelsford
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Jan 17, 2013 13:00 | #14 Why don't you consider an LED continuous light? I use an OTT Lite all the time for macro and have recently added a pair of these, which are amazing as you can cotrol the color temp and power. Canon EOS R
Jan 17, 2013 13:30 | #15 Needsnow wrote in post #15500874 Why don't you consider an LED continuous light? I use an OTT Lite all the time for macro and have recently added a pair of these, which are amazing as you can cotrol the color temp and power. http://www.outdoorphotogear.com …o-and-dslr-led-light.html I've been meaning to look into these as a bit of a cheaper option,but not really seen any use of them as of yet! Could you post a photo to show me the result please? http://500px.com/ChrisBrelsford
| Latest registered member is johntmyers418 1241 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
