Thread started 12 Jan 2013 (Saturday) 11:42
60D or 7D
Jay ­ B
Jan 12, 2013 11:42 |  #1
Just dunked my 50D in water. No I didn't do it on purpose. (See Error Codes posting farther down). Depending on the cost I may be replacing it rather than fixing it. the 60D and 7D are the only 2 that are in my price range. Since I don't really care about the video which would be closer to the 50D as far as performance goes? Which one would you upgrade to?
My camera doesn't take great pictures.....I do! :rolleyes:
Canon 50D
EF-S-18-55 IS / EF-S 55-250 IS / EF-S 60 Macro / Sigma 150-500/ EF-28-105 (Burned out motor) Tamron 18-270, Sigma 17-70
vsg28
Joined Aug 2012
Jan 12, 2013 11:43 |  #2
7D for sure
Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
mesakid
Jan 12, 2013 11:54 |  #3
7D. Make sure to check used market.
https://www.youtube.co​m/that1cameraguy (external link)
A9|A7RIII|A6500|A6400|​A6300|A6000
michgirl
Gallery: 13 photos
Jan 12, 2013 11:55 |  #4
I vote for the 7D!
Robin
Canon 6d / EF Lens: 24mm-105mm / 40mm f/2.8 / 28mm f/1.8 / 50mm f/1.8 / 85mm 1.8 / EF 70-300mm II USM
Canon T6i / EFs Lens: 24mm Pancake / 18-55mm STM / 18-135mm STM / 55-250mm STM
waterrockets
Joined Jun 2010
Jan 12, 2013 12:01 |  #5
Video not important, maybe consider the 1D Mark III or IIn, depending on intended use. 60D and 7D are both great though.
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
tickerguy
Joined Dec 2012
Jan 12, 2013 12:19 |  #6
7D has superior AF and continuous shooting speed (by a lot), 60D is lighter and has a swivel screen which is quite useful for video.
The 60D, however, has good AF capability for OUTDOOR moving things. Indoors or under poor light the 7D blows its doors off in terms of being able to nail a focus lock.
The 7D is quite a bit more money though and requires CF cards (also more expensive, and not by a little either!) where the 60D uses SD cards.
7D also has microadjust where the 60D does not (and IMHO this is a bummer, as if you get a lens that front or back-focuses on the 60D there's nothing you can do other than send it to Canon and ****.)
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
RHChan84
Joined Apr 2011
Jan 12, 2013 12:20 |  #7
Between those, 7d since it has the mag alloy body, dual processor, better AF and the MFA that 60d doesn't have. But if the swivel screen interest you and missing those features is not an issue then 60D.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
1Tanker
Jan 12, 2013 13:00 as a reply to  @ RHChan84's post |  #8
The 7D is most "similar" to your 50D in terms of build, ergonomics, and layout(and uses the same memory cards, and remotes).
The 60D is most "similar" to your 50D in terms of performance ( AF, FPS,) and only lacks the MFA.
That said, 60D's seem to have less issues with AF with lenses from the factory, than 7D's. The AF seems to have more latitude/more forgiving, so the lack of MFA is not as big an issue as it's made out to be.
If money isn't a concern, the 7D might be a better "fit" for you..although the AF will take some getting used to. If money is a concern, the 60D is still an awesome body, and i highly doubt it would leave you wanting.
Kel
Gear
tickerguy
Joined Dec 2012
Jan 12, 2013 13:36 |  #9
That's a good point -- on my 7D you actually NEED to use the MFA, particularly with wide-aperture lenses.
I was convinced that my 7D body was very slightly out of alignment right up until I tested my 70-200 f/4 for MFA required corrections (the last lens I jacked onto it to do so) and found it was dead-balls on at all focal lengths. Zero MFA required. The very same lens on my 60D is tack-sharp while my 50 f/1.4 front-focused a bit on the 60D -- just enough to annoy me a bit. On the 7D that same lens was UNUSABLE in autofocus up close at wide apertures - until I nulled it out with MFA. Now it's very nice.
I know that doesn't make any sense; a variation in the distance between the mount and sensor should impact all lenses identically. I can't explain this from a physics perspective -- but it is what it is.
jhayesvw
Gallery: 167 photos
Jan 12, 2013 13:40 as a reply to  @ tickerguy's post |  #10
Why not pick up another 50d on the used market for $500 or less?
My Flickr (external link)
1,279 views & 0 likes for this thread, 9 members have posted to it.
60D or 7D
500 guests, 120 members online
