Thread started 12 Jan 2013 (Saturday) 13:11
problem using extention tubes. need help
ekfaysal
Jan 12, 2013 13:11 |  #1
first of all, i'm sorry if im posting in wrong section. couldnt figure out where to post this macro extension related question
now here is the thing
today i got my cheap macro extension tubes from ebay
its manual tube. im using 60D with 50 1.8, 18-55 and 55-250 lens
now the thing is , i know i must have to manually focus plus manual exposure.
but i cant get it right. i have tried with my all 3 lenses.
the image is always blur. it never gets sharp. i been trying to set manual focus plus shuffling ISO and Shutter-speed, but i cant get it right.
any help ?
thanks
INSTAGRAM @FAYSAL9 (external link)
DreDaze
Gallery: 49 photos
Jan 12, 2013 13:13 |  #2
get closer...you have to get really close...and if you're like me you put all 3 on at once...in which case you have to get really really close...:)
but bottom line is you're too far away
also you don't have to manually expose(wait, i just saw you have the manual tubes, maybe you do, although i still doubt it)...set the lens to AV mode, and you should get the correct shutter speed...if there's not enough light, then motion blur could be affecting you, and if you have enough light then the DOF being so shallow could be a problem
Andre or Dre
gear list
Instagram (external link)
gjl711
Jan 12, 2013 13:21 |  #3
past a sample. Need more data.
Light? Needs lots and lots of light.
Shutter speed? Need to be pretty fast as even micro movements will impart lots of blur.
Mirror lock up? It helps reduce camera shake.
Tripod? The closer it is to a ton of iron, the better. ;):)
Aperture? Even at f/11 your DOF is going to be razor thin.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
ekfaysal
Jan 12, 2013 13:31 |  #4
DreDaze wrote in post #15479355 (external link)
thanks alot for the reply
and yes. that was the thing. i was using all of the three at once :D
Plus i was not too close to the subject as well
tried it now. n it worked well,
Thanks alot.
as for manual exposure thing . well there is no aperture thing when the extension tube is attached. so i guess the aperture wud be locked , im having control of just shutter speed and ISO i guess.
oldvultureface
Gallery: 85 photos
Jan 12, 2013 13:32 as a reply to  @ gjl711's post |  #5
You'll also want to set a smaller aperture for closeups. Since the tubes don't transmit aperture information, mount the lens you want to use directly on the camera. Set the aperture you want and press the depth of field button to close down the iris. With your third hand (while holding the DOF preview button with your second hand), press the lens release and twist off the lens. The aperture will now be locked at your desired setting.
You can now mount the tube(s) and lens on the camera.
s.l.k
Joined Mar 2012
Jan 12, 2013 13:37 |  #6
ekfaysal wrote in post #15479404 (external link)
You could set the aperture, hold the DOF preview, and remove the lens, then attach it to the tubes. Kind of a pain though.
EDIT: oldvultureface beat me to it
Feedback
oldvultureface
Gallery: 85 photos
Jan 12, 2013 13:39 |  #7
s.l.k wrote in post #15479430 (external link)
Yeah, but it's the thought that counts. :)
Snowyman
Gallery: 682 photos
Joined Oct 2011
Jan 12, 2013 13:46 |  #8
Buy a set of tubes with the electrical connections, Polaroid, Kenko and a few others do them. Tubes without control of the aperture will either make you the most accomplished manual photographer in the World or the most bitter, twisted, deranged and forlorn person on Earth. My money would be on the latter. In short; you haven't saved any money by buying cheap tubes, you have bought a World of pain.
Snowy's Gear
Deviant Art (external link)
500px (external link)
ekfaysal
Jan 12, 2013 14:02 |  #9
thanks guys
all of you
it really helped me :D
im now gonna play with ext tubes n will try to capture some cool macros
Wilt
Jan 12, 2013 16:36 |  #10
It is quite common that a very short FL on the wide-to-short-tele zoom lens will result in needing to have the object 'inside the lens' for it to be in focus...the focus distance is not possible. Try setting your zoom FL to at longest setting when using the extension tube, and you will likely be able to achieve focus. Then you can shorten FL progressively until you discover the limit at which it is impossible to achieve focus.
You should be able to achieve focus with the 50mm f/1.8 and extension tube...just keep trying until you get focus, then note the focal plane-to-subject distance...it will be quite close with long extension tube use.
ekfaysal
Jan 13, 2013 15:23 |  #11
Well, Thanks everybody for suggestions.
you guys rock
i saved money and got the cheaper one. n iknow its gonna be pain to capture macros each time
Here is what i experiment today.
practically my first macro shot :D
Thanks everybody.
IMAGE: http://farm9.staticflickr.com/8324/8378197080_f802abec23_b.jpg
IMAGE LINK: http://www.flickr.com …lsphotography/8​378197080/  (external link)
My little macro (external link) by faysalelahi (external link), on Flickr
oldvultureface
Gallery: 85 photos
Jan 13, 2013 15:38 as a reply to  @ ekfaysal's post |  #12
Nice. Which one of your lenses did you use? It's very sharp.
Nevermind. I saw it in the 55-250 thread.
ekfaysal
Jan 14, 2013 06:35 |  #13
oldvultureface wrote in post #15483535 (external link)
Yeah. that was with 55-250... n did some post processing as well.
1,696 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
1053 guests, 115 members online
