bboysmax wrote in post #15485863
Would that be the same as just shooting in jpeg instead of RAW? Because it seems pointless shooting in RAW then converting to jpeg anyway.
Sorry if i'm missing something here
DPP's default edit will be very close to the way the camera would have processed a jpg for that file, according to your camera setup - Picture Style, WB, sharpening, ALO, etc - but the DPP defaults are only "suggestions" that haven't been applied yet and therefore can be freely changed and rechanged without detracting from the image quality or directly affecting the Raw data. A jpg has first had the camera's edits "baked" in and then a large amount of the original data is thrown away as it is converted from 14 bits linear data to 8 bits logarithmic data. The Raw has wide latitude for processing and the jpg has much less flexibility if you want to edit it. In other words, by shooting Raw and processing in DPP you are leaving yourself the option to either accept the default Canon processing or to create your own processing.
You can do all the basic editing in DPP - anything that involves global changes in color and/or tone (brightening, darkening, contrast) and fairly good input sharpening and noise treatment. If you want to do more in a second editor you can export a 16 bit tif instead of a jpg, which will provide a better basis for further editing.
