Thread started 15 Jan 2013 (Tuesday) 05:29
Video card recommendations?
adammazza
Jan 15, 2013 05:29 |  #1
Hi, just built out a new PC for Lightroom/Photoshop editing. I'm currently using the onboard video (Asus P8Z77-V LX mobo).
I'm probably going to go to 2 monitors soon, and will be looking into getting an add on video card. Any recommendations on low end cards? This machine will not be used for gaming or video editing.
Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Canon 70-200mm L F/2.8 IS
Canon 24-105mm L F/4.0 IS
Sigma 35mm F/1.4, Sigma 85mm F/1.4
Fuji 16mm F/1.4, Fuji 35mm F/1.4, Fuji 56mm F/1.2, Fuji 16-55 F/2.8
ben_r_
-POTN's Three legged Support-
Jan 15, 2013 11:20 |  #2
Do a search for a nVidia card at Newegg.com in your price range and pick one with good/high reviews.
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jan 15, 2013 14:10 |  #3
adammazza wrote in post #15490661 (external link)
Whats wrong with using the current video outputs from the on board video?
I have a similar spec Gigabyte board that I use to drive two 24" Dell's using the DVI and VGA connections on the board.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
YP5 ­ Toronto
Jan 15, 2013 15:23 |  #4
You wouldn't catch me using VGA as a connection with the quality of monitors being used today.
Adam, what is your budget?
Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
Allen ­ K
Jan 15, 2013 15:32 as a reply to  @ YP5 Toronto's post |  #5
As that particular board has both DVI-D and HDMI connections, it should be a problem. I run 3 monitors...one off of the MB and the other two off of an HD 6770.
Allen - Gear List
Moppie
Moderator
Gallery: 22 photos
Joined Sep 2004
Jan 15, 2013 15:39 |  #6
YP5 Toronto wrote in post #15492704 (external link)
I can't tell the difference if I connect my 2711 over display port or VGA, same with the 2410 sitting beside it.
The two 2412 I have running off DVI and VGA also look exactly the same once calibrated.
adammazza
Jan 15, 2013 18:13 |  #7
Didn't have a budget in mind ;). Picked this up:
http://microcenter.com …4MB_GDDR5_PCIe_​Video_Card (external link)
Another reason for this is that I was having problems calibrating with Color Munki. Getting Unable to set LUTs errors which I think was related to the driver.
Adam
tickerguy
Joined Dec 2012
Jan 19, 2013 19:15 |  #8
My recommendation is this:
http://www.newegg.com …aspx?Item=N82E1​6814130835 (external link)
Will handle up to 4 monitors simultaneously. Two DVI, one HDMI and one Display Port. Yes, it will drive all four outputs (I'm doing exactly that.) A pair of cables will turn the DVI and HDMI ports into DVI connections at the monitor end if required.
If using calibrated displays (E.g. ColorMunki) you need to turn off LUTs in the program settings but this is true for ALL multi-monitor configurations off a single card.
It's EXTREMELY fast but reasonably priced and if you do any sort of video work most of the common NLEs can use the GPU for rendering acceleration as well.
Adam: On the ColorMunki "FILE" menu (top left) go into the preferences and uncheck the two boxes for DDC and LUT. Your problem will go away; ColorMunki will prompt you through the process of manually balancing brightness and contrast for each monitor, then perform its magic.
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
adammazza
Jan 20, 2013 15:33 |  #9
tickerguy wrote in post #15509776 (external link)
Thanks. Great tip. I actually bought the card I mentioned above along with a Dell U2410 monitor. All is good now.
2,344 views & 0 likes for this thread, 6 members have posted to it.
1335 guests, 169 members online
