Ok here's my problem. I'm a portrait photographer and currently own the ef 50.14, and 135l. I just sold my 24-70 2.8l and I want to have a focal length to cover wider then 50mm. I have enough in my budget to either go with the 16-35, 17-40, or the 35 prime.
My main question is I also get real estate gigs usually in the spring through summer months. Which leads me to think the 16-35 or 17-40 is a better choice and if I do go for the 17-40 I could also pick up a 85mm1.8.
So what the hell should I do here? Can the 16-35 be used and perform well as a portrait lens? I know for real estate it is more then capable.
Is the 17-40 ok to use in portrait situations, or is the 16-35 a better all around lens.
Or should I go 17-40 and also pick up a 85 1.8?
Thoughts?
