Thread started 08 Jan 2006 (Sunday) 08:42
Problem with new EF 70-200. Need help.
Pinto
Always in our hearts and minds. R.I.P.
Joined Jan 2005
Jan 08, 2006 08:42 |  #1
I think I'm in trouble with my new 70-200 2.8 IS. After seeing such great images from others with this lens I'm very disappointed
On my 20D It seems to be relatively crisp out to about 15 or 20 feet and then the IQ becomes very poor. Images just seem to be OOF. Is this symptomatic of a particular problem anyone is familiar with?
I was hoping that it was user error, but I've shot over 100 images, (all in RAW format) just trying to get something I consider sharp, or comparable to other images I've seen from this lens, and I can't get there. Could it somehow be related to the body?
I'm a designer with competent post skills so that is not the problem.
I have not read of even one person on this forum having a problem with this lens. I feel bad about asking for an exchange on this lens and I have to do it today or send it to Canon to look at.
The following is a sample image.
Any help or suggestions would be greatly appreciated. Thanks.
Mike
Pinto
Joined Jan 2005
Jan 08, 2006 08:47 |  #2
Another sample image. I shot about 35 images of this hawk on my back fence and not one was sharp enough to keep.
Tsmith
Formerly known as Bluedog_XT
Jan 08, 2006 08:56 |  #3
First off if your not happy return and exchange it today. Not knowing all the variables involved it does seem way too soft. Have you tried using it attached to a tripod to rule out user error?
Pinto
Joined Jan 2005
Jan 08, 2006 09:02 as a reply to  @ Tsmith's post |  #4
I used a mono-pod and I'll put it on a tri-pod just to be sure but so many images and no keepers. Thanks.
Tsmith
Jan 08, 2006 09:09 |  #5
Not owning that Lens but using my f/4L's and seeing others results with that particular Lens it should be tack sharp from f/2.8 ~ f/8 for sure.
Pinto
Joined Jan 2005
Jan 08, 2006 09:14 |  #6
That's what I assumed. Kind of a shock.
ddelallata
Jan 08, 2006 09:21 |  #7
Just send/take it back for an exchange. Those pictures don't look very good. My non IS version is getting much better results at any distance.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
Michaelmjc
not cool enough
Joined May 2004
Jan 08, 2006 09:23 |  #8
Whats the exif info on the shots? EDIT, sorry I see it now. Where was the autofocus point selected tohugh?
Yyz Design (external link)
Pinto
Joined Jan 2005
Jan 08, 2006 09:25 |  #9
Center focus point on all.
Michaelmjc
not cool enough
Joined May 2004
Jan 08, 2006 09:37 |  #10
I would take it back immediately, they look pretty awful. That sucks though, good luck with it.
GyRob
Jan 08, 2006 09:43 |  #11
send it back even the kit lens would be better than these .
Rob.
"The LensMaster Gimbal"
Pinto
Joined Jan 2005
Jan 08, 2006 09:58 |  #12
That's kind of brutal but you are probably right! LOL
Tsmith
Jan 08, 2006 10:02 |  #13
Did you buy it locally or order via the web?
cdifoto
Don't get pissy with me
Jan 08, 2006 10:06 |  #14
Damn. No pixel-peeping necessary. That's an outright horrid copy.
Ronald ­ S. ­ Jr.
Prodigal "Brick" Layer
Gallery: 12 photos
Jan 08, 2006 10:09 |  #15
Did you buy it new? Also, I know the IS works on a tripod/monopod, but did you try turning it off? Last, did you try a focus test?
Mac users swear by their computers. PC users swear at theirs.
4,617 views & 0 likes for this thread, 14 members have posted to it.
917 guests, 160 members online
