Thread started 20 Jan 2013 (Sunday) 11:55
walking in the snow
Paul ­ Bailey
Joined May 2012
Jan 20, 2013 11:55 |  #1
Recent walk with my daughter emma.
IMAGE: http://farm9.staticflickr.com/8076/8395039391_d3330a42e9_b.jpg
Canon EOS 550D 18-55mm isII kit lens
Canon EF 75-300mm 1:4-5:6 III USM
Extention Tubes
+1,+2,+4,+10 Closeup Filters
Prior Planning And Preperation Prevents Poor Performance..:D
Mataz426
Joined Feb 2012
Jan 20, 2013 13:20 |  #2
This is a good example of checking the histogram (even though we can see the whites are not white) but I bet the histogram shows all grey / middle values and to the left. You should have over exposed by a stop minimum.
ResolutionMax
Joined Jan 2013
Jan 20, 2013 22:49 |  #3
^ agree.
If you have the Raw file, you can improve this a lot - it is a good capture.
Trent
5D MK II : 24-70 2.8L II : 70-200 2.8L IS II USM : Canon EOS M5
tkbslc
Jan 20, 2013 23:12 |  #4
Just needed a little curves and fill light/clarity. Easy fix. Basically since your subject is the girl, and not the snow, you have to decide to blow out the snow to make sure the girl is properly exposed. Spot metering or using +1 or +1.5 EC in snow is a good idea. If It was my own, I might try to preserve a little detail in the snow and fine-tune the color balance a bit.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/3/LQ_633707.jpg
Image hosted by forum (633707) © tkbslc [SHARE LINK]
Taylor
EOS Rp | iPhone 11 Pro Max
chazpages
Joined Nov 2012
Jan 20, 2013 23:47 |  #5
looks good!
leeleeRT
Jan 21, 2013 05:32 |  #6
With the exposure fixed, it's a very nice image.
"There is nothing worse than a sharp image of a fuzzy concept" - Ansel Adams
"Models make the best photographers" - Tyra Banks
www.focusure.com (external link)
5DM2/15mmfish2.8/70-200mm2.8IS/50mm1.2/105​mm2.8macro/16-35mm2.8/24-105mm4.0/etc, etc - cert. gear junkie
Paul ­ Bailey
Joined May 2012
Jan 21, 2013 15:51 |  #7
Thanks for the comments and input much appreciated as allways ;)
Extention Tubes
HappySnapper90
Jan 21, 2013 17:15 |  #8
Sweatpants and tennis shoes for a walk in the snow...
1,990 views & 0 likes for this thread, 7 members have posted to it.
walking in the snow
2564 guests, 97 members online
