Thread started 21 Jan 2013 (Monday) 16:33
WD Passport 1TB vs. 2 TB?
Roxie2401
Jan 21, 2013 16:33 |  #1
Looking for portable storage and wondered if there are any pros or cons to getting the 2TB version vs. a couple of 1TB "My Passport" drives.
Any experience? I see the 2TB is only a little more in cost and wondered about failure rates, etc.
tickerguy
Joined Dec 2012
Jan 21, 2013 16:49 |  #2
No direct experience with those in particular but lots with WD drives in general. With the exception of a bad batch of 320GB disks that I ran into a few years ago (firmware problems, not the physical assembly itself) I haven't had trouble with WD in quite a while, and I use a lot of them. My expectation would be that the difference would be the price and size ;)
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
_aravena
Jan 21, 2013 16:51 |  #3
I prefer Seagate but WD has still served me well.
Last Shot Photography
trewyn15
Joined Dec 2012
Jan 21, 2013 17:39 |  #4
They're virtually the same construction just one's larger. You shouldn't have an issue with failures if you treat it right.
Mitch
Canon T3 - Canon 60D - Canon Rebel 2000
Canon EOS M - Canon PowerShot SD1100IS
Gear/Feedback
Roxie2401
Jan 21, 2013 19:19 |  #5
_aravena wrote in post #15517039 (external link)
Any particular Seagate portable drive?
jemanner
Jan 21, 2013 19:30 |  #6
Using three 2TB WD My Passport drives at work for nightly backups, rotating them offsite weekly. I also store 250 GB worth of personal photo files on these drives for offsite (from home) safety. No problems over the last several months. Would recommend them highly. This said, for my primary photo drive I use a 1TB Buffalo Ministation with no issues. No matter what drive, backup-backup-backup.
Jim
bps
Jan 21, 2013 22:51 |  #7
Roxie,
The is no measurable difference in failure rate between 1TB and 2TB hard drives, nor is the difference in the reliability between Seagate and Western Digital. I would suggest simply buying the right sized drive for your storage needs and go with either of those two bands...whichever one is cheaper at the time you buy.
Hope this helps,
Bryan
My Gear List
Trique ­ Daddi
Jan 21, 2013 23:00 |  #8
I prefer WD over Seagate. I have a 1TB Seagate and a 500GB and a 2TB WD. None have failed but I have two friends with Seagates that failed. I double backup on two separate drive. I am now trying to use a dock that you can plug internal hardrives into. Still wiating on the hardrive to ship. Best of luck!
Canon 7DMKII,7D 40D, 20D, CANON 100-400mm IS 4.5/5.6L, Canon 70-200mm 2.8L, Canon 50mm 1.8, Canon 100mm 2.8 macro, Kenko Extension Tubes, Sigma 17-50mm F2.8 EX DC OS, 580EX II Flash,Gittos MH 5580 monopod, Thinktank Airport Takeoff.
Pi_314
Jan 21, 2013 23:29 |  #9
Always bought WDs, but then there was the time I picked up a Seagate, and it died rather quickly. Needless to say which one gets the nod from then on.
mike_d
Jan 22, 2013 00:45 |  #10
Every brand has failed.
Every brand will fail.
Buy whatever is on sale.
Backup your stuff.
_aravena
Jan 22, 2013 05:32 |  #11
mike_d wrote in post #15518610 (external link)
Backup your stuff.
This. I just had two WDs fail me and no Seagates. The WDs I just bought a new enclosure and they worked fine so it wasn't the drive itself, just the enclosure.
Roxie2401
Jan 22, 2013 06:45 as a reply to  @ _aravena's post |  #12
Thanks for the advice and suggestions.
At this point, I'm beginning to think it may make sense to just get two 1TB "My Passbook" drives and keep two copies of my photos The "backup the backup" philosophy....
Right now, my image library size is running around eight GB RAWs - but it does grow more quickly with the 5D III file sizes.
tickerguy
Joined Dec 2012
Jan 22, 2013 06:56 |  #13
Yeah, the problem is that you need a multi-level backup strategy so you never trust one device to be "the one" -- or you will eventually lose whatever is on "the one."
That's a absolute certainty.
In my more than 30 years of doing this in the tech field I can tell you that the "best disk drive" company changes from time to time and it's impossible to predict who's in the "turkey box" and who's in the "good box" at any given point. By the time you find out it's too late. There are particular models I avoid, but not brands.
jemanner
Jan 22, 2013 07:20 |  #14
tickerguy wrote in post #15519099 (external link)
Absolutely agree. Poor design, different drives from different manufacturing facilities, even a "bad run" on the assembly line. Plenty of variables to contend with.
Jim
Roxie2401
Jan 22, 2013 15:53 |  #15
Well, since you mentioned this - care to comment on the current "My Passport" by Western Digital?? Good, Bad, current line - where are these drives made, etc.
10,841 views & 0 likes for this thread
Latest registered member is Guashumerda
876 guests, 212 members online
