Thread started 22 Jan 2013 (Tuesday) 18:12
? About IS
Kylemorgan88
Joined Oct 2011
Jan 22, 2013 18:12 |  #1
What does X-Stop (2-stop, 3-stop, etc) IS mean?
I understand basic principles behind IS, but I don't understand using the metric "stop" to further define or place measurement on the Image Stabilization technology.
Is stop in any way related to a stop of light?
Nightdiver13
Unabashed nerd!
Jan 22, 2013 18:17 |  #2
Yep, same term as stop of light. Just means that the IS has the potential to allow you to shoot at a shutter speed x number of stops slower than without IS.
Neil
Bonbridge
Gallery: 20 photos
Joined Jan 2012
Jan 22, 2013 18:21 |  #3
Yes. It is a stop of light.
So if you shoot something without IS and get it stable at 1/200th of a second.
With a 4stop IS you can get 4 stops slower shutter. So you could get a 25th of a second exposure with the same results, if you move your hands the same :)
With a 3stops IS you will can get the same result at one 50th of a second with the example above.
With a 200mm lens you need about 200th (I think) of a second or faster if you don't want to see any blur (caused by shakey hands and body) in the image. With a good IS you can go to a lower shutterspeed. And if you can drop your shutterspeed you can shoot with a lower ISO and don't have to use the lens wide open as much, if you want too.
5DII + 6D | 16-35/4.0L IS | Σ35/1.4A | 40/2.8 | Σ85/1.4A | 70-200/2.8L IS II
iMac Retina 5k | i7 | 24Gb RAM | 512GB Flash | 4GB M295X
Website (external link) | flickr (external link) | Instagram (external link)
Kylemorgan88
Joined Oct 2011
Jan 22, 2013 18:44 as a reply to  @ Bonbridge's post |  #4
How does Canon (or other brands) measure the effectiveness (# of stops) of their IS technology?
Also, how many stops is the IS in the new 70-200 IS II?
msowsun
"approx 8mm"
Gallery: 18 photos
Jan 22, 2013 19:08 |  #5
Normally at 200mm the slowest shutter speed you should use is 1/200.
Canon claims 4 stops worth of Image Stabilization on the 70-200 IS II so you can expect to shoot at 4 stops slower shutter speed and still get sharp results.
4 stops slower than 1/200 would be 1/30 (1/200 > 1/100 > 1/50 > 1/25)
962 views & 0 likes for this thread, 4 members have posted to it.
? About IS
1114 guests, 111 members online
