doidinho wrote in post #15524625
Did you have the color checker laying on the floor facing the lights when you shot It?
If so, that orientation wouldn't take the bounced light from the court floors into account. If the floors were wood, the bounced light from the floors would have a red cast.
The solution would be to shoot the color checker at an angle next time so that is illuminated by both the lights and the bounced light off of the floor.
I did have one side laying on the floor and the other facing at a 30 degree angle up. So you are saying I should have stood it up so both were seeing reflected and direct light? It was hard to position it without some shadow on the color chips. The floor was a grey volleyball portable flooring, so not wood or red. There wasn't really anything red for it to reflect I don't think.
zerovision wrote in post #15524643
I have the passport, LR4 and all of my images look fine. When creating a profile this brightens the colors of the image, but does not adjust the WB. In order to get a proper WB in LR with the passport, you can either use the passport and do a custom WB in camera or take a pic of the passport under the location lighting and use the dropper in LR to select one of the gray squares.
The passport provides several gray squares that are for portraits or landscapes. These all have slight color adjustments so that you can add warmth to the image, such as skin tone.
OK, I totally was not looking at this correctly. I was thinking the profile would take into account and correct WB, but now I see what you are saying and not sure why I thought that. So if there is a red cast, then it was probably already there and exaggerated with the enhanced color. After looking back at the images today, I'm not seeing as much of a cast, so maybe it was the contrast from the uncorrected images that left me "seeing red". I'll attach an image as a reference. This still has the WB set by Expodisc. I'll try selecting some of the ColorChecker chips as alternative white balance.
Here's an image with the ColorChecker profile, and lens profiles applied, and Exposdisc WB. Other than that, the only adjustment is a very minor Clarity addition, and minor noise reduction. These are the least tweaked I've ever had to do indoor sports images.
5D3, 70-200 2.8 IS II, f/2.8, 1/640s, ISO 5000, RAW, Custom WB from Expodisc
