Just got a Metz 50 AF-1 to go with my 430EX II that I use off camera with the ST-E2.
95% of the time I will have the 430EX in manual mode and everything is grand.
With the Metz, I can seem to trigger it in SL (slave) mode but only with the Metz in ETTL mode. If I want to use the Metz in manual mode I have to put it in Servo mode. The problem here seems to be that the ST-E2 wont trigger it, but 430EX is supposed to trigger it. But in Servo mode the Metz ignores the first flash and waits for a second flash? (It thinks any first flash is a preflash I think), so it is ignoring the 430EX flash.
I've read though the manual and messed around with them. Anybody else have this combo and have both flashes working off camera with the ST-E2?
P.S.
Thinking back on the testing I did earlier, with the 430EX in manual and the Metz in Servo (manual, optical slave) , I'm thinking only the Metz flash showed up in the photo, which doesn't make any sense at all? Ignore this bit for a while and I will double check.
