Thread started 25 Jan 2013 (Friday) 20:18
New Monitor issue with Gain and offset
tvphotog
Jan 25, 2013 20:18 |  #1
Just got a new Dell U3011, which has Gain and Offset controls for RGB. The default for Gain is 100%. When I calibrated with Spyder 4 Pro, I had to reduce the blue and green just a bit, but that did the trick.
When it came to brightness which I wanted to set to 120, I started out with a default of 50%. Even when I reduced it to 0%, I could only get the brightness to 125. Should I just leave things there, or should I reduce each of the RGB's to 75% each, and then repeat the above. Will that allow me to reach a lower brightness of 120 or less?
And how do I use the Offset controls, or should I touch them?
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
butterfly2937
Gallery: 378 photos
Jan 31, 2013 17:12 |  #2
tvphotog wrote in post #15534306 (external link)
Are you using the expert mode on the Spyder 4? I found that works the best and it will walk you through adjusting the RGB Gain if needed.
GEAR
tvphotog
Jan 31, 2013 17:20 |  #3
butterfly2937 wrote in post #15557389 (external link)
Not sure how to find the setting for expert mode. Didn't know there was one. HOw do you set it up?
Jay
butterfly2937
Gallery: 378 photos
Jan 31, 2013 17:23 |  #4
tvphotog wrote in post #15557426 (external link)
Open the spyder 4 software > bottom left corner drop down menu > expert console
GEAR
tvphotog
Jan 31, 2013 17:43 |  #5
butterfly2937 wrote in post #15557441 (external link)
I have 4 Pro which doesn't have the expert console. You must have the elite version. What's the expert console allow you to do?
Jay
butterfly2937
Gallery: 378 photos
Jan 31, 2013 18:36 |  #6
tvphotog wrote in post #15557502 (external link)
Yes I have the Elite version ( sorry I missed the fact you were using the Pro version )
Manually set the White point, Gamma, Black Luminance and White Luminance either use the Ambient measurement suggested or over ride it and use your values only. You set Red Green Blue Gain only if needed based upon the chart in the expert console ( You basically adjust to line up the RGB values until the bar is even on the chart). It also gives you advanced analysis options at the end of the calibration. I found this mode to be the most accurate and therefore I only use the expert console. I tried both methods and the expert mode gave me a very accurate calibration.
GEAR
tvphotog
Jan 31, 2013 19:29 |  #7
butterfly2937 wrote in post #15557670 (external link)
Cool, am upgrading and will sell the Pro on the Selling Forum. Thanks a lot.
Jay
2,749 views & 0 likes for this thread, 2 members have posted to it.
1014 guests, 107 members online
