Thread started 26 Jan 2013 (Saturday) 08:26
Pantone Huey + Windows 8 = Fail?
cdifoto
Don't get pissy with me
Jan 26, 2013 08:26 |  #1
I bought a new laptop with Windows 8 and for the life of me cannot get a successful calibration with the Pantone Huey. It will read the ambient but it fails immediately upon attempting the color profiling. It's a Vizio CN15-A5 if it helps any. My old Acer under Windows 7 calibrates fine with the same Huey.
It's not a case of the obvious...ie it doesn't fall off and the monitor isn't dirty. It just fails. Does anyone have any light they can shed on this? I'll buy a new calibration device if this one isn't compatible but I don't want to buy another if it's something I need to change in my settings or whatever. The Acer, for what it's worth, only has onboard graphics and the Vizio has dedicated Nvidia graphics if that makes a difference.
Thanks in advance!
CxThree
Jan 26, 2013 21:00 |  #2
I'm using the Huey pro on windows 8 right now. Dual Dell monitors on a home PV I build (Core I7, 16gbRam, ATI video, etc.). It works perfectly fine. I'm not sure why its failing for you. I don't think its a Windows 8 issue though.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
cdifoto
Jan 26, 2013 21:05 |  #3
I just have the plain Huey so it might be that. A little bit ago I managed to get about halfway through the calibration colors but then it failed the same way.
CxThree
Jan 26, 2013 21:08 |  #4
Hmm. It sounds like it's not seeing the calibration colors or something. Sorry I could not be more help.
4x 600EX-RT
mike_d
Jan 26, 2013 21:08 |  #5
It could be a communication issue. Is it plugged straight into the PC or are you going through a hub?
CxThree
Jan 26, 2013 21:13 |  #6
Its going through the USB ports on the monitor which plugs to the pc.
4x 600EX-RT
tonylong
...winded
Gallery: 60 photos
Jan 26, 2013 21:15 |  #7
Have you checked with Huey, for new drivers or such?
Tony
cdifoto
Jan 26, 2013 21:17 |  #8
mike_d wrote in post #15537945 (external link)
It's going straight into the PC. I only have two ports and both fail.
tonylong wrote in post #15537968 (external link)
Yes I have the latest software. Sadly though it's hasn't been updated in a while. I'm suspecting an incompatibility since it doesn't say specifically that 8 is supported.
CxThree
Jan 26, 2013 21:22 |  #9
Check your bios settings for any USB settings. Turn on legacy USB support, etc. See if it makes any difference.
4x 600EX-RT
mike_d
Jan 26, 2013 21:23 |  #10
Kind of a long shot, but try setting the Compatibility Mode to Win7 and run it as an administrator. I have a PC that I had calibrated with Huey prior to upgrading to Win8. I haven't had any issues but I haven't tried to recalibrate since upgrading. I should probably try.
cdifoto
Jan 26, 2013 22:31 |  #11
CxThree wrote in post #15537997 (external link)
I went into the BIOS the other day and there are no USB settings to be found so no luck there unfortunately. It's quite bare bones actually.
mike_d wrote in post #15538002 (external link)
Hm. Not a bad idea. I'll give that a go. Do report back if you manage it before I do.
tkbslc
Jan 26, 2013 22:37 |  #12
cdifoto wrote in post #15537934 (external link)
huey pro = huey
the pro just unlocks the software to allow calibrating multiple monitor setups.
Taylor
EOS Rp | iPhone 11 Pro Max
cdifoto
Jan 26, 2013 22:54 |  #13
tkbslc wrote in post #15538241 (external link)
huey pro = huey
I just meant software-wise. I'm just a basic owner. The software versions are not the same.
cdifoto
Jan 26, 2013 22:55 |  #14
No dice on the administrator/compatib​ility modes. I also did find USB legacy support in the BIOS after all but it was already enabled.
tonylong
...winded
Gallery: 60 photos
Jan 26, 2013 23:57 |  #15
One other thought is to ensure that you have up-to-date graphics card drivers -- I've heard of problems being fixed by updating them.
Tony
11,622 views & 0 likes for this thread, 5 members have posted to it.
1613 guests, 141 members online
