the.forumer Senior Member 415 posts Likes: 1 Joined Oct 2011 More info | Jan 26, 2013 09:12 | #1 see above for reference. this was shot with a 5dc using the following settings: 1/400 f2.8 iso800 the photo did not have any 'black blocks' before i used a +1EV brush on the hand. in the past, i've never had such a problem.. but recently i get these weird artifacts once in a while. anyone had the same issue before? it's not normal, cos for some photos where i'm on iso3200 and i smack a +1EV on it, those artifacts wouldn't appear. it's certainly not noise; otherwise a 100% NR would have somewhat reduced this blocking effect - but it didn't, at all.
Rimmer Goldmember 1,416 posts Likes: 4 Joined Nov 2010 More info | Jan 26, 2013 10:26 | #2 Delete this Adjustment Brush, turn of Auto Mask, and try it again. I think you will find that you get good results this time. Ace Rimmer -- "What a guy!"
Jan 26, 2013 16:28 | #3 yep its the automask. Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
Jan 26, 2013 19:00 | #4 Rimmer wrote in post #15536003 Delete this Adjustment Brush, turn of Auto Mask, and try it again. I think you will find that you get good results this time. just curious, how does the auto-mask produce these black artifacts? i thought it's supposed to just detect the edges so you can brush easily.
tonylong ...winded More info | Jan 26, 2013 20:35 | #5 I don't see a shortcut for Auto Mask. Tony
doidinho Goldmember 3,352 posts Likes: 23 Joined Aug 2007 Location: Kenmore, Washington More info | Jan 26, 2013 20:39 | #6 the.forumer wrote in post #15537552 just curious, how does the auto-mask produce these black artifacts? i thought it's supposed to just detect the edges so you can brush easily. anyway, is there a keyboard shortcut to enable/disable auto-mask? seems like a feature i'll miss ![]() I'm curious too, I'm guessing that its making the noise. Robert McCadden
tonylong ...winded More info | Jan 26, 2013 20:51 | #7 I've never seen artifacts from the auto-mask -- is there a discussion/documentation about this somewhere? Tony
hwan Member 153 posts Joined Dec 2012 Location: St Louis, MO More info | Jan 26, 2013 22:27 | #8 The problem with automask is that it uses intensity detection or something like that to figure out where the boundaries are and which pixels are selected. So in places that's noisy to highly textured, it will leave gaps like that. If you press 'O' to turn on the mask overlay, you will see holes at some pixels which are not selected. You're much better off zooming in and using a smaller brush when working around the edges. Don't forget that you have the erase option to paint over areas where you went over the boundaries. Olympus E-M1 | 12-40mm f2.8 | 17mm f1.8 | 75mm f1.8 | GT1544T + Q3T
Jan 28, 2013 15:03 | #9 hwan wrote in post #15538206 The problem with automask is that it uses intensity detection or something like that to figure out where the boundaries are and which pixels are selected. So in places that's noisy to highly textured, it will leave gaps like that. If you press 'O' to turn on the mask overlay, you will see holes at some pixels which are not selected. You're much better off zooming in and using a smaller brush when working around the edges. Don't forget that you have the erase option to paint over areas where you went over the boundaries. This is exactly what's happening. Auto Mask IS finding the edges. It's just not finding the edges that you want it to. Instead, it's finding the tiny little edges of all the texture on the subject you're trying to paint. http://www.avidchick.com
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Jan 28, 2013 20:02 | #10 One thing that initially got me with the adjustment brush was that the erase brush has no option to reduce the density. It took me a while to work out that painting over an area that had been painted at say 100% density with the brush at 10% density reduced the density to 10%. I found this the hard way when I had painted in an area at 100% and then wanted to add an area next to it at much lower density. I just thought I would be able to do that by painting up to and over the area already painted in at 100%. That's the way I have been used to painting in layer masks for years, so the change was a bit of a surprise.
tonylong ...winded More info | Jan 29, 2013 00:18 | #11 First, try the Overlay ("O") function when brushing and especially when erasing. Zoom in close and you can see the Overlay (reddish by default) showing you where you have brushed (and so where to erase). Tony
Bearmann Goldmember 1,228 posts Likes: 57 Joined Feb 2008 Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme. More info | Jan 29, 2013 12:41 | #12 That automask stippling has plagued me for years! Thank you all for the explanation and solution! Barry
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | As above the auto mask can result in some areas of your subject not being selected. If this happens try adding with auto mask deselected (so the whole area you want gets painted) then run along the edge with a smaller remove brush with automask selected. Because you are working just on the boundary line auto mask works much better. Dan Marchant
| Latest registered member is semonsters 1504 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
