Hey guys,
Seems like lately my Canon 580 II flash has been over exposing my shots pretty badly. (BTW i bounce my shots in the same way i would my 430 light 95% of the time with absolutely no problem using my 430 in the same way).
I own both the Canon 430 II, which i used heavily for over 3 years with absolutely no problems and then decided to buy the 580 II thinking it would be even better than my 430.
This flash has rarely seen any use int eh 2 years since i have owned it since I have always prefer the look of the photos i get using fast L primes over anything flash can offer me.
Anyways, make a long story short. The last two times i used the 580 II during X-mas and New years at family gatherings, indoors, the results were horrible. The flash seems to over expose the photos i take extremely bad in ETTL. This is far from the case of the photos obtained using the 430 while using the same technique.
Another problem is that since this so called great flash was rarely used in the time since i purchased it, the warranty is long gone. So i'm on my own on this problem.
I sometimes seem to get a few good shots then BAAMM. 4 bright, burned out, super bright, and what seems like full power shots. Needless to say the photos i took during these two nice, memorable events had to be heavily PP'd with Light room, wich in some cases saved a few some what but most came out horrible.
What can be causing this? Has anybody else here had a similar problem, read of similar problems or know of something going on with the 580 II that is common with this flash? I really need your help here because i would really hate to have to spend 500 bucks on a new one and don't want to have to send it in. Very annoying to have to do that to me.
Also, do you think there is a way to revert it to factory settings to see if this helps.
Thanks for the great help in advance, Al.
P.S. You guys are great are resolving stuff like this for me in the past and hope this is another problem i can fix on my own. Thanks again!!
5D-2 Mark ii
