Thread started 27 Jan 2013 (Sunday) 17:43
Change Rotation of Warp Selection?
doidinho
Jan 27, 2013 17:43 |  #1
I would like to warp something that is at an angle and would like the rectangular warp box to be at an angle too, rather than be at the same allignment of the frame.
The attached selection is roughly the angle I want the warp box to be at.
Is there anyway to do this.
I could make a copy of the image, rotate and crop the image so the bottom edge of the selection is parallel to the bottom of the frame, carry out the warp, and then unrotate and place the warped area back into the correct location, but that seem like more work than it should be.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/4/LQ_634718.jpg
Image hosted by forum (634718) © doidinho [SHARE LINK]
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
doidinho
Jan 27, 2013 17:49 |  #2
This is the warp box I get if I try and warp that selection.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/4/LQ_634720.jpg
Image hosted by forum (634720) © doidinho [SHARE LINK]
Robert McCadden
MM (external link)
Wilt
Jan 27, 2013 18:05 |  #3
It seems you already have your Verticals correct, so all you really need to do is to change the Aspect Ratio of the shot, if you are trying to make the corner of the eves fall at right angles to each other.
For example, in Resize you might magnify Horizontal by 1.13 (or whatever factor gets you there) while magnifying Vertical by 1.0
Wilt
Jan 27, 2013 18:09 |  #4
I see now that the roof corner is about 90 degrees already, but the edges of the roof are curves rather than straight lines. I'm now stumped on reducing curvature of field along the diagonal!
doidinho
Jan 27, 2013 18:52 |  #5
Wilt wrote in post #15541036 (external link)
It's a 4 shot pano at 24mm usingthe 24-105; thus the distortion.
I'm going to try my rotation/crop idea.
Robert McCadden
MM (external link)
pbelarge
Joined Jun 2010
Jan 27, 2013 18:58 as a reply to  @ doidinho's post |  #6
Get a ladder, a hammer and some shims. That should do it. :D
just a few of my thoughts...
Pierre
Redcrown
Jan 27, 2013 22:41 |  #7
Take a look at puppet warp for tasks like this. I found it a bit intimidating at first, but after the learning curve, I find it faster and easier than the old transform/warp. Google "puppet warp to straignten" for several eaxmples. Here is one that's close to what you are trying to do.
http://www.youtube.com …er_embedded&v=A​nmJRl8R6fY (external link)!
doidinho
Jan 28, 2013 08:24 |  #8
Redcrown wrote in post #15541984 (external link)
That's a great idea. I will try it when I get home, thanks.
Robert McCadden
MM (external link)
kirkt
Jan 28, 2013 10:02 |  #9
If you are using CS6, the Adaptive Wide Angle tool will permit you to straighten that curved edge. Without knowing how you generated the panorama, I cannot suggest THE way to do it in the AWA tool. If you stitched the panorama in CS6, the AWA tool should recognize that. If you did not, you may need to play with the mode in which the tool works (panorama, auto, etc.) to see which one gives you the tool's ability to model the distortion you are gong to correct.
kirk
Kirk
doidinho
Jan 28, 2013 20:42 |  #10
kirkt wrote in post #15543368 (external link)
kirk
This was the the tool for the job, thanks.
It's a pretty amazing tool in the way you can apply multiple constraints in real time and then adjust as necessary before accepting the change.
Robert McCadden
MM (external link)
kirkt
Jan 28, 2013 21:03 |  #11
Yep. I agree.
kirk
Kirk
1,721 views & 0 likes for this thread, 5 members have posted to it.
1061 guests, 104 members online
