Thread started 28 Jan 2013 (Monday) 03:49
Question about battery grip.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Jan 28, 2013 03:49 |  #1
Does it use both battiers at the same time? Or does the grip use one battery first and when that is done, it starts on the other one?
How do you know when one of the two batteries is low/needs a charge?
Can you use just one battery in the grip?
Thinking of buying one today, mainly for the vertical grip.. i carry two batteries with me everywhere so i don't really need the grip for the extra length in batterylife.
Thanks in advance.
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
DavidR
Jan 28, 2013 05:09 |  #2
You can use one battery in the grip. If two batteries are used, then they are both used simultaneous.
Sony a9II
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Jan 28, 2013 05:39 |  #3
Thanks.
X-Pro1 XF 35 f/1.4
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Jan 28, 2013 15:29 |  #4
Bought it, it's pretty pricey but i really like it, takes some time getting used to it.
The store manager said that the batterygrip uses one battery at the time and not both simultanious.. i really don't care since i only use one and keep the other one in the bag.
X-Pro1 XF 35 f/1.4
charles_leon
Joined Oct 2012
Jan 28, 2013 19:04 |  #5
im not sure exactly how it works but id occasionally check the battery info when using the grip. i have a 60d as well, and it shows for each battery how many pics were taken with each. seems like they alternate in a way. but usually one is a bit higher than the other in terms of use
6D. 16-35L f4. 50L. 135L
pfjbaldwin
Jan 28, 2013 19:09 as a reply to  @ charles_leon's post |  #6
Have used Canon battery grips for many years shooting sports. One battery always was way more discharged than the other when it came to charging them post shoot.
pfjohnsonphotography.c​om, pfjphoto.com, Baldwin, MD
CPS
mike_d
Jan 28, 2013 19:11 |  #7
pfjbaldwin wrote in post #15545561 (external link)
This is my experience with the Canon grip on my 5D.
Numenorean
Jan 28, 2013 19:40 |  #8
DavidR wrote in post #15542686 (external link)
Mine uses one at a time...at least it seems to as one takes much longer to recharge than the other if my battery shows 50% left.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Jan 29, 2013 01:44 |  #9
charles_leon wrote in post #15545545 (external link)
Yea, that menu is great and it shows both statuses of the batteries. Guess the clerk was right.
But to me it feels safer to just use one battery in the grip and once that is discharged, i can switch to a 100% fully loaded.
X-Pro1 XF 35 f/1.4
1,911 views & 0 likes for this thread, 6 members have posted to it.
1456 guests, 128 members online
